How does the interior light housing come out?
Old Jul 25, 2015 | 11:36 AM
NightScreams's Avatar
Question How does the interior light housing come out?
The 2 button lights above you, how does that whole housing come out? I don't see any screws, does it pop out?
Old Jul 25, 2015 | 01:56 PM
Mr.Hollow's Avatar
Are you trying to replace the bulbs to LEDs? You just use a pry tool to take off the clear pieces.
If you are trying to remove the whole assembly, it is most likely just in there with side clips so a pry tool should pop it out.
Old Jul 25, 2015 | 02:58 PM
I pried some with a pry tool but didn't want to put too much pressure on it until I knew for sure what's holding it in there. But it didn't budge, the liner is giving.
Old Jul 26, 2015 | 02:39 AM
Mr.Hollow's Avatar
hmmm... there maybe some sort of assembly diagram in the parts catalog. Check out an online parts catalog from any honda shop and usually there is a engineering type diagram of all the pieces. That might give a clue.
Old Jul 26, 2015 | 04:44 AM
Black3sr's Avatar
Pry the lenses out. There are two screws inside to remove the entire unit.
Old Jul 26, 2015 | 03:52 PM
By lenses, you mean the plastic buttons and those just pry out?
Old Jul 26, 2015 | 04:21 PM
Black3sr's Avatar
Yes. Use a credit card to pry them.
SilverEX15
Apr 17, 2018 10:27 AM
Santiad
Jul 3, 2016 10:29 AM
Fitguy07
Aug 11, 2009 01:14 PM
CrystalFiveMT
Feb 7, 2009 08:16 PM
adashjr
Sep 14, 2008 05:19 PM
