clicking sound when braking. any thoughts?
Old Jan 7, 2016 | 01:43 AM
spin out's Avatar
any thoughts on this: recently i've started hearing a clicking sound (for lack of a better description) coming from the rear when i brake. the sound only happens occasionally, but daily. sometimes it happens when i brake hard, sometimes it doesn't. sometimes it happens when i brake at slow speeds, but sometimes it doesn't. any thoughts on the matter are appreciated!
Old Jan 7, 2016 | 12:11 PM
Mister Coffee's Avatar
Any other symptoms? Does the car pull, vibrate, knock, etc., when you apply the bakes?
If we were talking about the front, I would say that this could be a non-issue — simply the pads moving a little as you apply the brakes. But you have drum brakes in the rear, and, frankly, I'm not an expert on drum brakes.
Old Apr 17, 2018 | 10:58 AM
tedmondsjr's Avatar
Similar noise just started on my car (2012 sport, manual, 70K miles). Resurrecting this thread to see if anyone else had a similar issue and how it was resolved.
Old Apr 17, 2018 | 02:35 PM
spin out's Avatar
i received an email notification of a reply in this thread, otherwise i wouldn't have ever seen it. i literally don't remember starting this thread, nor the problem i described. i guess the problem went away on its own.
but, FWIW, later in 2016, i occasionally heard a crunching sound when i hit the brakes for the first time on trips. months later, i had a "full brake fluid flush" and the crunching sound went away. apparently Honda recommends this service every 36,000 miles, and it is completely independent of the standard brake fluid job.
BunnyHopper1981
May 17, 2017 09:17 AM
zachhart12
Nov 12, 2012 12:55 PM
Piyo2005
Aug 21, 2012 05:25 PM
.eL
Jun 25, 2010 01:41 PM
Halcyon
Mar 15, 2010 11:04 PM
