Replacement 'drainage' cover for bumper?
Old Apr 14, 2016 | 03:24 PM
cgwaters's Avatar
The rear bumper of my 2013 Fit is missing the circular cover that hides what appears to be a drainage hole:
Rear bumper
This is the same type of cover which is on the front bumper:
Front bumper
Can a replacement cover be purchased?
Attached Thumbnails Replacement 'drainage' cover for bumper?-80-rearbumper_c6d4a94aed3f19640b08aaaf448abb7ca48eb41e.jpg   Replacement 'drainage' cover for bumper?-80-frontbumper_5355474ac878fe1412ab102d10d4952e343af609.jpg
Old Apr 14, 2016 | 06:29 PM
BenQuick's Avatar
This may be it but it's called a towing hook cover.
OEM Honda Part 71504-TK6-A00ZC | Rear Towing Hook *NH578* Cover
Old Apr 14, 2016 | 06:46 PM
DrewE's Avatar
Ben's got it covered (no pun intended). That is the threaded connector for the tow hook, not a drainage hole. Before ordering a cover, check to see if by chance you have one in the spare tire compartment with the screw eye/tow hook that just never got put back on.
Old Apr 18, 2016 | 04:52 AM
mtheo31's Avatar
You can also find those oem towing hook cover on ebay though a bit more expensive.
Old Apr 19, 2016 | 02:36 PM
cgwaters's Avatar
Thanks, everyone! I neglected to mention that about a month ago the cover became detached but remained hanging off the bumper via a short plastic string. I tried to place the cover back on the towing hook hole but it kept falling off. (The vehicle was purchased used from a dealer last fall.) About two weeks ago, the cover and string disappeared altogether; I'm guessing someone pulled it off.
I don't see any damage to the bumper or to the towing hook hole that would have caused the cover to fall off. If I purchase a replacement cover, I'm wondering what will prevent it from falling off.
Old Apr 19, 2016 | 06:09 PM
DrewE's Avatar
The cover has a couple little plastic prongs/clips that snap into the notches at the top and bottom of the hole in the bumper cover. I'd guess that your original cover had one or both of these worn or broken off. Mine stay in position quite well. It doesn't look from your picture like the bumper cover is mutilated at these notches, at least as best as can be made out in the small size.
Old Apr 19, 2016 | 07:35 PM
littleblackcar's Avatar
Is it possible to get a hook to screw in there? That could be used to tie down a kayak's bow and stern.
Old Apr 19, 2016 | 08:42 PM
vegajf's Avatar
Sure.
Just get the hook out of the jack tool kit, screw it in.
Old Apr 19, 2016 | 09:07 PM
Originally Posted by vegajf
Sure.
Ha! I had no clue!
Old Apr 19, 2016 | 10:56 PM
Oneoldphlaytis's Avatar
Be aware that the roof of the 2013 Fit dents really easily.
Old Apr 20, 2016 | 10:48 AM
cgwaters's Avatar
Thanks! Here's a closeup of the bumper cover:
I'm guessing it would have no problem keeping a replacement cover fastened.
Now I'm wondering if the original owner had to have the vehicle towed!
Attached Thumbnails Replacement 'drainage' cover for bumper?-80-rearbumpercloseup_b060554a33f0e8844b4d7bb5fb0b1206c1b300e2.jpg
Mike Houser
Jul 18, 2014 08:51 PM
MTLian
May 29, 2014 11:16 PM
OutkastGS3
Oct 17, 2009 01:12 PM
Sloto200
May 7, 2008 10:43 AM
roenyc
Aug 15, 2006 10:29 PM
