12 volt line in hatch area
Old Jan 15, 2017 | 03:47 PM
Sal Coraccio III's Avatar
Hi all,
I've searched, sorry, can't find the answer.
I'm installing a power adapter like what you'd plug a cigarette lighter into (except not); has to go in the hatch area. Didn't look like any wires back there power on anything full-time
Any suggestions for a place I can pull 12 volts?
Gen 2, 2010, btw.
Thanks you.
Old Jan 16, 2017 | 09:17 AM
spike55_bmw's Avatar
Don't you have a courtesy light on driver's side in the side panel? That has wires. Depending on the load you put on the 12VDC cigarette outlet, you might blow a fuse.
Old Jan 16, 2017 | 08:14 PM
DrewE's Avatar
The hatch area light is not powered all the time, but only when the hatch is open (or was recently opened). I'm not aware of any constantly powered 12V lines in the cabin in back of the dome light.
If you're using this outlet when the rear seats are folded down, it might be appropriate to install it in the rear part of the center console, which would be a pretty easy wire run to the lighter plug circuit or some other appropriate place. Otherwise, I think you're stuck with running another wire. I think, if I remember correctly from the parts diagrams, that the main wiring harness runs along the sills of the doors, presumably under the plastic trim pieces there.
HarleyBadger
Jan 21, 2018 12:42 PM
SilverEX15
Jan 10, 2015 05:51 PM
Chad T
May 14, 2013 08:38 PM
ratedz
34
Aug 29, 2009 02:53 PM
Fit4Pits
Aug 28, 2009 11:28 PM
