Code p0171
Old May 30, 2018 | 08:40 AM
Arthur33's Avatar
Code p0171
Hi, i just installed a short air intake, was ok now i have a check engine light on with code p0171 . What can i do to fix this issue, i'm thinking i'm might just put the factory air box back in, i have no luck with this intake. I have a intake on my element and no issue's, i guess this car is picky. Please help , thank you
Old May 30, 2018 | 01:58 PM
Bluepunk18's Avatar
Make sure you plugged the MAP sensor back in?
Old May 30, 2018 | 02:27 PM
Arthur33's Avatar
Hi, i double checked the electrical connection's and all hose's, everything looks rite. Just the code p0171
Old Jun 11, 2018 | 01:26 PM
Arthur33's Avatar
Anybody else know why i got the p0171 code after the short intake install, i checked it twice, took it out, put the factory air box back in and no more code. I don't understand what's the problem i even cleaned the maf sensor with the rite cleaner. I've done a cai in my honda element and my silverado, no issues
Old Jun 11, 2018 | 11:28 PM
xxryu139xx's Avatar
with my prm intake, the maf sensor had to point straight into the tube, and the perpendicular pointing towards the rear of the engine. match the orientation of it to the oem box.
Old Jun 12, 2018 | 07:10 AM
Arthur33's Avatar
Hi, yea i had the part of the maf sensor with the little opening with the diode facing the filter, and the closed end of the maf facing the tb. My cheap kit don't have the silicone hose that goes into the intake tube and the valve cover, i messaged the guy i bought it from and he didn't respond back, so i was thinking maybe that's why i got a code p0171. I installed the factory air box, and no more code. And the maf is facing the same way in the factory box as i had it in the aluminum tube.
Great Evil
Apr 8, 2025 02:38 PM
prhkgh
Apr 3, 2014 07:09 PM
jazzhands68
Dec 28, 2011 02:58 AM
Pang3t
Sep 22, 2011 08:50 AM
FELIXY69
Feb 27, 2009 03:41 PM
