Need help with stuck driver's seat
Old Sep 2, 2018 | 05:07 PM
skier2.0's Avatar
I have a 2012 Honda Fit Base. The driver's seat is stuck in the furthest back position. I couldn't see a coin and was at wits end so I went to the dealer. $85 later, I was told that it would be a $1300 repair since the rails are "bound up."
On the driver's side, the 81526-TK6-A01 Seat Back Frame (roughly $900) is just a couple of parts that I believe includes the rails, seat frame, and latch. (See diagram.) I know that I can find an OEM part shipped for a couple hundred less, but it's still too much money.
I found 2 threads about precautions when removing front passenger seat (i.e. remove air bag fuse, disconnect battery).
https://www.fitfreak.net/forums/2nd-...sassembly.html
I think I have found a full left driver seat assembly for the correct years--I am just waiting to confirm that it is from a Base model and not the Sport.
Due to safety concerns about the air bag, I cannot just pop this used seat in. 1) At first I was thinking of getting this seat and stripping the whole thing down to the frame parts I need. Then I could let the shop go for it with 3 hours of labor. 2) Or could I take the newly purchased seat, have them install it, but keep my seatbelt, air bag, and/or key safety parts.
What do you think is my safest option?
Last edited by skier2.0; Sep 2, 2018 at 05:10 PM. Reason: Typo/omitted last sentence when copying
Old Sep 2, 2018 | 06:07 PM
GAFIT's Avatar
Go here... car-part.com
Put in your location, 2009-2013 Honda Fit, and "seat track" for the part. I see them ranging from $35-75 in my area for the drivers side seat tracks.
Removing them seat is SUPER easy. Disconnect battery, remove 4 bolts, unplug a few connectors and remove the seat. Then swap the rails.
Old Sep 4, 2018 | 06:35 PM
skier2.0's Avatar
Unfortunately, the passenger side has the seat track, but it appears that the driver's seat is not the same.
Old Oct 27, 2019 | 05:03 PM
plaster's Avatar
How do you disconnect the rails from the seat? I can't find any obvious disconnection points nor any diagrams online.
voip-ninja
Sep 4, 2018 06:36 PM
fitbuddha
Apr 19, 2015 04:32 PM
Sarah Hodge
Mar 30, 2015 06:27 PM
parahands
Aug 18, 2014 08:48 AM
RobR
Jun 9, 2006 02:27 PM
