Bad PCV Valve
Old Oct 9, 2018 | 01:59 PM
Henus's Avatar
Bad PCV Valve
What are normally the signs that normally show the PCV valve is getting bad?
Old Oct 10, 2018 | 10:08 PM
SiXiam's Avatar
They last a pretty long time. They can get clogged, so take it out and look. Losing oil seems to be the big symptom, but it could just be running a little worse.
Take it out and shake it. Should rattle. If it looks old just change it. Not worth much effort for a cheap replacement.
Old Oct 10, 2018 | 10:31 PM
Henus's Avatar
Thanks cause I am loosing oil and feel its the pcv valve but see no oil on air filter, no smoke nor oil leak. Only thing that lets me think its the valve is that in the area it is located is very greasy.
Old Oct 11, 2018 | 07:35 AM
spike55_bmw's Avatar
Well, if you start out with the proper oil level in the crankcase and you don't see any oil dripping off of the engine, the only way out is to the atmosphere is through the combustion chamber. Again, you don't see any oil spots on the pavement where the car is parked and/or you don't see oily residue on the bottom on the engine / car surfaces?
There are two routes to the atmosphere through the combustion chamber: in the old days, valve covers had "breather caps" that allowed crankcase pressure & oil fumes to escape but now that is controlled by the PVC system of valve & tubing that feeds back into engine intake at some location. OR, the oil is leaking into the combustion chambers around bad valve guides or bad piston rings. With the volume of loss you're experiencing, I'd have to say that there should be some oily residue on the surface of the exhaust tip if not "blue" smoke and/or the odor of burning motor oil if you sample the exhaust fumes with a "calibrated" nose.
Your spark plugs could provide some info. If they are black / oily then you know that the oil is being burned: bad valve guides, piston rings, PVC system. If only one / two spark plugs are black / oily then you can eliminate the PVC system because all spark plugs should be seeing the same amount of oil mist under that scenario. But a black / oily plug isn't good if you haven't seen the Check-Engine-Light (CEL) indicating a misfire. A misfire would say the the plug is bad, and if not firing, that cylinder could have weird pressure / vacuum cycles and be "sucking" oil past the piston rings / valve guides. All new plugs and possibly a new coil pack on the bad cylinder would fix it. Absent a CEL, that would indicate a bad cylinder system = $$$ because then it would be piston rings and/or valve guides.
Keep us updated, Thx
Old Oct 11, 2018 | 10:00 PM
Henus's Avatar
Will do its just funny how today my Fit gave such good performance and no smoke at all or leaks but am loosing oil.... Think if my engine was worn must wudof seen some obvious smoke by now so just gonna get a new PCV valve and hopefully that stops the prob. Vehicle drives like almost new.
Old Oct 12, 2018 | 11:20 PM
SiXiam's Avatar
After the PCV valve I would check the plugs and ignition coils.
Old Oct 12, 2018 | 11:30 PM
Henus's Avatar
https://www.youtube.com/watch?v=asUgoPci52k
does any one have a pic of how the PCV valves looks for a 2012 Japanese Honda fit?
Old Dec 20, 2018 | 02:17 PM
J20's Avatar
J20
It looks like a fat bolt with a hole/stem sticking out of one side. Auto zone pcv valve won't torque btw or it'll bust.
Hondafit2011
Oct 10, 2018 11:46 PM
doctor J
Dec 20, 2015 12:55 AM
SlavetotheHonda
Sep 27, 2015 09:28 PM
gizmodog
Nov 17, 2013 09:20 PM
SanDan
May 19, 2009 01:16 PM
