Time Chain Cover - leak... how important
Old Dec 18, 2018 | 12:49 PM
smetzger's Avatar
13 Fit with 80k miles.
Had the passenger side airbag recall done and the dealer says the timing chain cover is leaking.
There is no spotting on my driveway and the oil does not seem to be going down on the dipstick.
Given the above, how important is it to get this fixed?
Can I just monitor the oil level and then when the chain needs to be adjusted (100k miles??) get this done?
Old Dec 18, 2018 | 05:36 PM
ommegga's Avatar
Chain doesn't get adjusted. Youre probably thinking of valve adjustment.
Old Dec 18, 2018 | 07:33 PM
smetzger's Avatar
Ok, so how important is it that I get this fixed?
Old Dec 18, 2018 | 10:31 PM
ommegga's Avatar
If there is no spotting , I wouldn't really worry about it much. Just do it when ready or when you start seaing oil on your driveway. But I warn you, replacing timing chain cover on GE8 is pain the a$$.
Old Dec 18, 2018 | 10:50 PM
smetzger's Avatar
Yeah, I was thinking it would be something I could do. But then I took a look at it.... Thus the question.
Thanks
Old Dec 18, 2018 | 10:53 PM
justus's Avatar
Keep an eye out on the oil level on the dipstick...
If you really want... a nice piece of cardboard(that is spotless- super clean) whip it under the engine area on the ground
make sure it is large enough, encompassing the all important areas under vehicle that you want to check for drips.
make sure vehicle was ran to operation temps for a while..... then park it, say, for overnight...... check the cardboard in the morning....
Do this for a while......... or periodically............ Sounds like to me that they were probably looking to generate work for the shop.....(but what do I no?)
Old Dec 20, 2018 | 02:01 PM
J20's Avatar
J20
If the oil pressure is good I wouldn't worry about it. But if you're still worried tell him to show u exactly where the cover is leaking. Timing Cover or the valve cover? Either way both can be fixed by cleaning it off with a degreaser and putting a nickel size swab of gasket over the leak. Doubt it's the timing cover though. It comes with a thick gasket lining from factory. Most likely you probably spilled oil when u did an oil change.
Old Dec 29, 2018 | 03:41 PM
Steve244's Avatar
I agree with everyone else.
Dealer service departments like to point out oil leaks. These are labor intensive fixes to replace a seal, making them lots of money.
Old cars drip oil. Don't worry about it unless it starts using excessive oil (or you see puddles on your driveway). If the drops bother you, put a drip-pan under it.
Old Dec 29, 2018 | 07:51 PM
justus's Avatar
Drip pan, Here Here!..... Yeah for sure!
You can also run a little thicker oil.... as well...... like 5w30........
(instead of the Sewing machine oil we run in cars today) It may however effect fuel economy... a little
Fitnjammin
Dec 20, 2018 12:06 AM
gerard6496
Oct 5, 2017 07:25 AM
mecevans
Jun 4, 2015 09:26 AM
zymo
Oct 18, 2012 08:34 AM
EHONDA
Jun 12, 2012 06:38 PM
