GE OEM Cruise Control Retrofit? Any successful ones?
Old Jan 12, 2019 | 06:32 PM
mk2mike's Avatar
Hello,
I am sure this has been covered, but I could not find it using the search function.
I recently picked up a used 10' Tidewater Blue BASE model Fit as a commuter.
I did not think to look for cruise control on the car when purchasing it. Realized it did not have it when I got it home (wasn't a big deal breaker anyway), I looked into options.
I see an aftermarket version but at $300, I figured why not look into OEM stuff w/ used parts seeing how these cars are old.
Anyway, my research has brought me here SO FAR:
The Fit uses the gauge control module as it's cruise control module.
Using a scanner, I performed a component output test and saw my Gauge Module DOES in fact have the Cruise lights in it.
I was found when monitoring live data in the Gauge Control Module, there are information lists for cruise control. Making me believe it will in fact work w/ a base instrument cluster.
I Purchased the cruise control buttons w/ harness for Clock spring. I found the Clock spring DOES NOT HAVE THE PINS for the cruise control. '
Also found I will need to add wiring from the Clock spring connector to the gauge control module as the cruise control switch inputs are not there.
This is where it gets tricky.
I now have to purchase a clockspring from a fit with cruise control. Better yet I am purchasing one w/ steering wheel audio controls as well so I can wire that up.
Old Jan 27, 2023 | 02:07 PM
jamesxbyrnes's Avatar
I know this is very old post and im not sure if you're even active on here anymore but im curious if you were successful with this?
GinoLicious
Jul 26, 2024 10:31 AM
sdavid12
Dec 4, 2017 08:11 AM
buznee
Sep 9, 2013 03:28 PM
GE8FTW
Mar 27, 2012 09:03 PM
Subhabrata Bhattacharyya
Oct 12, 2005 08:30 PM
