Is the "change oil soon" indicator really accurate ?
Old May 4, 2019 | 08:29 PM
punx45's Avatar
Originally Posted by GolNat
I'll be sending in an oil sample to Blackstone once the family Pilot tells me to change the oil. Usually around 10k miles. I am curious how the oil holds up going by the cars minder. It has Honda Semi-Synthetic oil and Honda filter so it's as Honda wanted it to be.
i should do that too, I’m around 25k since my last change in the fall
Old May 4, 2019 | 09:18 PM
Alfa38's Avatar
Which oil and filter are you using?
Most filters aren't recommended to go longer than 15k. When I've done 25k change interval (after doing oil analysis to determine it was fine) I changed the filter halfway through the oil interval and topped off with fresh oil to make up for the loss from changing the filter.
Old May 5, 2019 | 06:22 AM
urbie4's Avatar
Originally Posted by JerrySFL
The dealship will try and upsell to other recommended services that you may not need just stick to your required services in the owners manual.
We might also not that you're not required to go to the dealer -- by law, you can have service done by any mechanic, and this does not void the warranty. Even the owner's manual itself mentions this.
Meanwhile, in the screwing-up-oil-changes department, about 25 years ago, I was driving along in my '88 Hyundai Excel, when all of a sudden, the oil light came on. I shut off the engine and rolled to a stop. Started it again, but when the oil light didn't go out in a second or so, turned it off. Pulled the dipstick. Nothing. Called a garage for a tow.
They called me back to say, "This car has no drain plug -- your oil leaked out all over the road!"
I had done the last oil change myself, so I obviously must have had some serious brain fade and not tightened the plug enough, and in a few weeks of driving, it worked itself loose and fell out!
I held my breath and told them, put in a new plug, fill it with oil, start 'er up and see what happens.
No damage, and I drove the car another 6 years or so! This a HYUNDAI, at the time, the cheapest new car you could buy!
Urb
Old May 5, 2019 | 07:10 AM
punx45's Avatar
im using the extended life Mobil 1 oil and fram filter, but also a healthy dose of forgetfulness and neglect. I usually do the changes closer to 15-20. until recently my daily commute was close to 200 miles RT so the miles add up quick if you are busy a few weekends!
redhausman
25
Jan 19, 2015 12:59 PM
912
Nov 21, 2009 09:46 PM
Edwood
Jul 13, 2008 01:07 PM
OrangeBlossom
Aug 23, 2006 09:50 AM
billbob234
May 1, 2006 08:27 PM
