Project lighter, faster, stronger...
Old Sep 17, 2010 | 01:05 AM
  #101
insane_one's Avatar
very odd position of the front licence plate
Old Sep 22, 2010 | 01:36 AM
  #102
bmxman's Avatar
it's just off to the side...or do you mean something else?
Old Oct 11, 2010 | 04:10 PM
  #103
bmxman's Avatar
JDP rear spoiler install:
first let me say that I did not follow the instructions from JDP. So if you are planning on swapping out your spoiler do so at your own risk!
1. Get all the tools needed. There are not many I just used a panel removal tool and a 10mm socket. The panel removal tool will prevent you from scratching anything while you're working.
2. There are 2 of these on each side of the rear spoiler. Use your panel removal tool to pry them out carefully a lot of force is not needed.
3. Once the spoiler bolt cover pieces are removed you should see this. Now take your 10mm socket and remove the two bolts. You don't really have to worry about the spoiler falling it's on there pretty good.
4. After you get the bolts removed then you can remove the little aluminum brackets that the bolt covers snap into.
5. Now you can evenly apply pulling force to the entire rear spoiler. the spoiler has a few clips so you will feel some resistance but just keep pulling evenly and relatively straight back and the spoiler should come off.
Once you have it off it should look like this.
Old Oct 11, 2010 | 04:21 PM
  #104
bmxman's Avatar
6. After you get the spoiler off I removed all the little white plastic clips from the hatch. Then I swapped the bolt cover brackets over to the JDP rear spoiler. The brackets have a bit of tape on them so they should adhere to the JDP spoiler. Sorry but one of the pics didn't come out well.
7. Mount your new JDP rear spoiler and secure the bolts. There is no need to go all Incredible Hulk on the bolts just enough torque so the spoiler doesn't wiggle. pop the bolt covers back on and you're done
Antennae clearance:
Old Oct 11, 2010 | 10:58 PM
  #105
blackndecker's Avatar
Looks great mang!!1!:thumbup:
I have an idea for a major efficiency mod (hint....aero) that I'll be unveiling in the next few days. Figured this would be right up your alley
Old Oct 12, 2010 | 02:10 AM
  #106
bmxman's Avatar
Old Oct 12, 2010 | 02:32 PM
  #107
insane_one's Avatar
looks good mayn!
Old Oct 12, 2010 | 02:36 PM
  #108
ThEvil0nE's Avatar
*watching... learning and staying tuned*
Old Sep 4, 2012 | 12:16 AM
  #109
bmxman's Avatar
wow been so long since I posted here. Just hit a tad over 45K and my 3rd oil change popped up the code was A 12. I have added so many parts since I last posted here. I'll have to update this soon!
Old Sep 4, 2012 | 02:06 AM
  #110
555sexydrive's Avatar
Yeah going on 2 years shortly. Post those updates.
Pumpkintacos
Jun 24, 2023 09:54 AM
radioarno
Feb 5, 2018 11:53 AM
Nicotine
Jul 25, 2013 07:30 PM
h2oplaydamian
Jul 25, 2013 02:28 AM
StromsonFit
Jan 14, 2012 10:17 AM
