First Oil Change?
Old Nov 19, 2013 | 03:30 PM
DiamondStarMonsters's Avatar
Originally Posted by carolina_cruising
By this calculation, I'd be changing my oil every 5000 to 5500 miles (37 mpg avg calculated over 135 to 150 gallons)
How did you arrive at 135-150 gallons?
Real long post I made on here in one of the old oil threads that gets into it a bit. This method is used by many fleet managers. It does require a few assumptions along the way... but as a large scale rule it works well. Similar to using "Running Hours" for metering equipment use/abuse.
Old Nov 19, 2013 | 07:55 PM
13fit's Avatar
Works perfectly for fleet setups since they generally run the same route in the same time period.
When I had a job 40 miles away, working 6 days a week, I simply changed my oil once per 2 months, and changed the filter every other oilchange. That was with my d15b2 civic with over 200k miles at the time. SuperTech 10w-30 in the summer, 5w-30 synth in the winter
Old Nov 20, 2013 | 01:37 AM
Not exactly.. it has more to do with eliminating some of the variation in how a car can be driven using mileage intervals. 5000 rural interstate miles and 5000 miles on I355 are world's apart. Much more similar is the amount of heat and blow-by of a fixed 150gal being burned during the above forms of use, to put it simply.
Zero2Hero
May 5, 2019 07:10 AM
bugsfit
Aug 3, 2013 03:53 PM
Nawamin
Jan 20, 2012 03:48 PM
mkane
Nov 23, 2011 09:37 PM
mega56
Dec 5, 2008 05:29 PM
