What Part Is This?!
Old Mar 1, 2014 | 08:00 PM
ibeckman671's Avatar
What Part Is This?!
I'm having a lot of trouble finding the replacement part that you can see here, this trim panel on the passenger rear door:
Honda Fit door garnish - Imgur
The basic story goes like this: a couple of years ago a Thule roof rack was ripped off of my car and it damaged the top of the frame. I took it to a shop, got it fixed and it looks brand spanking new. Fast forward to now, the part pictured is now falling off. 3 little clips once held it into place and were broken upon removal by the shop - how they fixed it was just with shoddy glue. I can't even find instructions what holds the whole thing on, which is why I opened up the garnish panel on the inside hoping to reveal an answer (but I think it's held by a piece of plastic). I've finally bothered to sign up on FitFreak and ask you, Honda Fit GODS if you may know...
I can't find this part anywhere. Searching for Trim Pillar comes up with adhesive taped on carbon fiber panels. I suspect it is called a "Trim Pillar Garnish," but I can't even find it on Honda's estore.
Thoughts?
Old Mar 1, 2014 | 08:42 PM
Hootie's Avatar
Go to a Honda parts site like BernardiParts, look in the "Interior/Bumper" trim section, and find the "Molding - Protector" in the listings.
It should be either part number 72721-TF0-003 (right rear) or 72761-TF0-003 (left rear) which is listed as numbers 7/8 in the illustration. The part is listed as a Door Pillar Garnish. Please double check part numbers before ordering.
Edit: Here's a link to where I did the search...
http://www.bernardiparts.com/SearchO...onda-fit-parts
Old Mar 1, 2014 | 10:50 PM
De36's Avatar
Its called a "door applique" in automotive terms.
Old Mar 1, 2014 | 10:59 PM
De36's Avatar
Old Mar 2, 2014 | 11:20 AM
Funkster's Avatar
Looks like this is handled, but wanted to mention a lot of people will know what you are referring to if you reference C-Pillar trim as well.
Old Mar 2, 2014 | 01:54 PM
THANK YOU! You guys totally rock! It comes right off with a screw and then you can just replace the thing. Thanks again!
zaebra
Aug 23, 2017 02:02 PM
AuctionHugh
Apr 9, 2017 04:26 PM
GrayGhost
Oct 28, 2015 10:53 AM
Peterjens
Jul 19, 2015 09:10 PM
vwli
Mar 1, 2009 02:02 AM
