Manual Transmission Fluid Change at 60k
Old Oct 4, 2014 | 03:59 PM
regular.dude's Avatar
Hey guys,
I've not yet done a fluid swap in my '13 Honda Fit. The manual doesn't really have guidance on this other than the maintenance minder and the dealer didn't really tip me off that anything needed to be done.
Any forseeable problems doing it at 60k? I hope not, only problem I'm having now is that it's hard to get into first sometimes without moving through gears, but wanted to get everyone's opinion on this.
Old Oct 4, 2014 | 08:52 PM
I'm changing mine at 41k miles (this coming Tuesday).
Nothing wrong with changing it at 60k, to be honest, I'd have changed it earlier if I were you.
Old Oct 4, 2014 | 09:04 PM
Wanderer.'s Avatar
I changed mine at 65k, all is well. Fluid was cleanish and there was nothing on the drain plug (I don't know if it's magnetic or not lol)
Old Oct 5, 2014 | 05:32 PM
Eugene.Atget's Avatar
My '09 Sport MT MM gave me the code to change it at about 105k miles. So I changed it.
Old Oct 5, 2014 | 07:54 PM
nikita's Avatar
I'll probably change it at about 60k also. Redline MTL solved the notchy shifting on the BMW, so I'll probably use it. Same viscosity as Honda's recommended motor oil substitute. I dont know what exactly is in Honda's branded fluid, but I suspect it is nothing special. Automatics are fussy, manuals, not so much.
Old Oct 6, 2014 | 02:37 PM
i dont think i would get to 30K while i own my '12, but 30k is usually when i change my tranny oil.
Old Oct 6, 2014 | 03:39 PM
Got it changed. Everything seems OK although I still have a notchy shifter. Oh well, new problem.
I do city driving, color was good, no metal shavings (or not that much).
Old Oct 6, 2014 | 03:59 PM
Did you use OEM Honda MTF?
cakacon
Jul 26, 2023 05:30 PM
SleepyNyte
Oct 28, 2016 09:15 AM
Mrb42
Aug 13, 2015 10:52 PM
Paj
Jul 12, 2014 07:03 PM
Marrk
May 28, 2010 11:39 PM
