HELP!...SRS Unit not pulling any codes
Old Oct 10, 2014 | 01:53 PM
bhacker1994's Avatar
I purchased 2010 fit that was in an accident. Curtain and driver seat airbag went off. I replaced the airbags and seatbelt. Now, i brought it in to get the SRS unit scanned, and they told me they cant even scan it. Theres no communication from the computer. I dont know what my next move should be. I cant even drive the car because it has a salvage title and needs to get inspected before i register it. any advice would be helpful. thanks
Old Oct 10, 2014 | 05:33 PM
Goobers's Avatar
Return it back to the seller or drop more $$$ [than that Fit is worth?] on a mechanic (or dealer) to troubleshoot it?
Old Oct 10, 2014 | 07:16 PM
painterguy's Avatar
Senior Member
Did you replace the SRS unit also??? If not that also needs to be replaced then scanned for any remaining open circuits. If all is good you can reinitialize the SRS system.
Old Oct 13, 2014 | 06:45 PM
No, I did not replace the SRS unit. I had it reset, and apparently that didnt work. So theres no way around buying a new SRS unit? Do you know anything about salvage vehicle inspections in Wisconsin? Are they going to scan my airbag system, or could i just find a way to turn off the airbag light?
BradGuy
Oct 9, 2019 05:16 PM
zakiu
Dec 30, 2014 10:36 PM
lovelyfit
Jan 12, 2012 06:14 PM
lovelyfit
Mar 13, 2009 10:47 PM
lovelyfit
Mar 3, 2009 12:34 AM
