Overfilled manual trans
Old Oct 21, 2015 | 07:18 PM
sultanofslide's Avatar
Decided to change my fluid today and 2+ quatrs came out after I opened the fill bolt, my pan was 4 quarts and was almost full after I drained the trans. Has anyone else has grossly overfilled gearbox from the factory?
Old Oct 21, 2015 | 11:53 PM
bensenvill's Avatar
I did not do my trans fluid because I was overdue and needed a full flush.... my only experience is with other cars and this has been my personal experience... The fill holes are oriented that you can't overfill them (they pour out at the proper fill level)
Old Oct 22, 2015 | 12:45 AM
ezone's Avatar
4 quarts?
You drained the engine oil by mistake?
Old Oct 22, 2015 | 03:01 AM
Definitely not the engine oil, this all came out of the 17mm fill plug on the side of the trans and the drain bolt. This car has a lot of build quality issues, it must have been built on a Friday.
Old Jan 14, 2021 | 11:33 PM
DoesItFit?'s Avatar
Same thing for me. Went to check at 30k and it spilt out. Changing now at 47 at a good quart came out ABOVE the fill line. And no it wasn't blinker fluid!!!!
dvoisawesome
Dec 12, 2017 02:43 PM
Wafulz
Apr 30, 2016 03:27 PM
Nvillegas
Jul 6, 2013 04:45 AM
abgenre
Jun 5, 2013 12:24 PM
ACMierzeje
18
Apr 14, 2012 04:43 PM
