Fit4Spl Stereo Install Log
Old Oct 20, 2011 | 01:24 AM
  #81
Fit4Spl's Avatar
Originally Posted by CharlotteGE8Alex
my system hits over 145 db daily and about 157db at spl comp new honda fit kicker system - YouTube
I've been in this game a long time and honestly, I do not see your car even CLOSE to those numbers. Termlab doesn't lie nor does physics and your box is not only way too small to touch 150db+ you don't have the amplification to back it up either. Oh and just so you get an idea of what I have done here is a link to my db drag stats.
Competitor Stats: Chris Bortz
I've broken the 150db barrier on the old termlabs, and the new ones are MUCH harder to do that on. As well I have close friends who do break the 150db barrier so I know what kind of not only power but subs and enclosure it takes to do it.
So in short, back up your claim with a termlab legal score then I will believe it, otherwise your claims are just that claims and nothing else. Not trying to be a douche but I have been doing this way too long to NOT know better.
Old Oct 20, 2011 | 01:42 AM
  #82
ill_eagle94's Avatar
I'm just wondering, with the SAZ1500 and the pair of SA12s, knowing you've done the big 3 and whatnot, are you having light dimming issues? Are you running just one factory battery, or have you upgraded more?
I'm just wondering as I also have the SAZ1500 and a pair of SA12s. I just don't have a Fit quite yet.
Old Oct 20, 2011 | 01:54 AM
  #83
Fit4Spl's Avatar
No dimming issues, with the big 3 upgrade to 0AWG and changing out my battery to an audio performance battery I can full tilt the car and not see dimming. I also have figured out how to trick the ELD which controls the alternator output so that I always see 14.2+ volts, it's really simple just turn the fan to setting 2 and it will kick the alternator up to 14.2+.
Old Oct 20, 2011 | 08:38 AM
  #84
Awesome, thanks for the info!
Old Oct 26, 2011 | 06:39 PM
  #85
Fit4Spl's Avatar
Few new videos
Windshield flex - YouTube
Windsheild part 2 - YouTube
Inside view - YouTube
Just got my order of Secondskin Damplifier as well which will be going in this weekend if the weather permits.
Old Oct 26, 2011 | 07:32 PM
  #86
CharlotteGE8Alex's Avatar
how many rms you pushing? what size those speakers? what battery you using? i been thinking taking the battery try out and trying to fit a Kinetik 1800 or 2000 and adding a 1800 or 2000 in summit racing battery sealed box on the middle of the back seat on that hump
Old Oct 26, 2011 | 07:34 PM
  #87
Fit4Spl's Avatar
2 Sundown SA 12s and a Sundown SAZ1500d 1500watt amp, battery is a single Shuriken BT35 which is 950CA.
Old Oct 26, 2011 | 07:45 PM
  #88
i got 4 layers in all doors,roof,trunk,floor,hood check it out but it still vibrates but without the vibrating crappy noises vheck it out new honda fit kicker system - YouTube
Old Oct 26, 2011 | 07:47 PM
  #89
yea i got kicker zx2500.1 with kicker zx 350.4, had three 15 kicker L7s but Im down to two now. I like your set up, good to know theres still people that love bass and clear music as much as i do
Old Oct 26, 2011 | 07:53 PM
  #90
Fit4Spl's Avatar
Multiple layers of deadener are not necessary especially with the new deadeners that are out now where you don't even need to cover the entire panel with it to get the full effect of the product. I will have updates on here when I put in my damplifier and you will see it will not be fully covered panels but it will still do exactly what it is supposed to.
Old Oct 26, 2011 | 07:54 PM
  #91
i good way to save you rear veiw mirror from shaking so bad , i took off my mirror and wrap that ball joint tight with black electrical tape, cant even see the tape on there, my mirrior use to vibrate off on low notes sometimes and fall while i was driving, not anymore, i do have to push it down on the window slide connector every once in a while
Old Oct 26, 2011 | 07:56 PM
  #92
yea i agree with you about the layers, i got alot from my shop i work at and i got carried away with it, ha didnt wanna waste any
Old Oct 27, 2011 | 01:18 PM
  #93
you have any battery install pictures, does the battery fit , your battery handling up to that amount of watts?
Old Oct 27, 2011 | 02:14 PM
  #94
Fit4Spl's Avatar
Yes in this install log you will find pictures of the battery with the Big3 done, should be page 3 or 4.
Old Oct 27, 2011 | 05:16 PM
  #95
hell yea i just ordered the Shuriken SK-BT45 thanks man for all the info, i was gonna get the same as yours but the SK-BT45 is only slightly bigger, it to big ill just take the battery tray out
Old Nov 3, 2011 | 04:46 PM
  #96
MOTOMATT's Avatar
Question
Well redid the big3 wiring to 0awg today, had enough to do it plus a small piece left over, if I add a second battery I will need more but thankfully not another full roll.
Did you connect the 0 guage wire on the alternator under the stock wire?
Old Nov 4, 2011 | 11:46 PM
  #97
yea i did i keep factory wire and added the 0 quage to alternator
Old Nov 13, 2011 | 05:00 PM
  #98
BlueBoogers's Avatar
Good god that 1/0 makes the 1.5 look tinier!
Old Dec 3, 2011 | 01:55 PM
  #99
Fit4Spl's Avatar
Well I forgot to post my deadener pics so here they all are including the rear of the car which I just did today.
Got an amazing deal on some stuff from secondskin on the black friday special and got a chance to install some of it today.
So the back of the car is done, I have not driven it yet since I just got finished doing this not 10 mins ago. But I am anticipating a lot of reduction in road noise from the back of the car now.
BTW if you are wondering 25% coverage is all that is needed with the second skin product, my car's noise level went way down when I just had the doors done and the rear should now be ultra quiet. I went a little heavier on the rear because of the fenders being right there as well as the exhaust. But the rest of the car is right around 25% coverage.
Old Dec 9, 2011 | 06:39 AM
  #100
ouchxx's Avatar
bump this up. how is the install now? how much rms are you running in the car? ive bee looking to upgrade my system and want to run 1650wrms (450 = 2 components, 1200 = 2 kickers). what electrical components will i need to upgrade? i have a GD3.
