Adding a rear Sport anti-roll to Base?
Old Nov 8, 2011 | 10:40 PM
larrymcewin's Avatar
Howdy all -
I'm buying a base fit because I'm cheap. Down the road in a few years after I pay it off, I'm thinking about adding the anti-roll bar which the sport has.
Is that difficult? I'm imagining a quick trip to Honda's part counter, a couple of jack stands, and a ratchet.
How intense of a job is it?
Old Nov 8, 2011 | 11:15 PM
Goobers's Avatar
Originally Posted by larrymcewin
Howdy all -
not easy to add the stock RSB (its part of the rear torsion bar). easier to add aftermarket RSB.
Old Dec 5, 2011 | 08:59 AM
Racebrewer's Avatar
What Goobers said. Its welded in at the factory. Progress rear A/R is the way to go.
At the time I looked at the difference in price and what you got for the money and went with the Sport. If you are getting a loan what would the difference per month be?
John
Old Feb 20, 2012 | 03:04 PM
matt1357's Avatar
The progress rear sway bar is the one to get. 150$ with free shipping from clubrsx.com takes less than an hour to get on without taking the tires off (just jack the right side up slightly) I put it on my base a week after I bought it and felt a difference right away. I was reminded how great it was the other day when I drove another base without one and the car was leaning all over the turns and just felt sloppy. With the bar it feels like a honda or acura, without it feels like a old corolla or camry.
Old Apr 24, 2012 | 10:02 PM
spookyneo's Avatar
Great topic. I previously had a Progress Rear Swaybar on my Lancer Ralliart '06 and enjoyed it in every way. The stock one was 13mm while the Progress was 19mm. I can't imagine how good it would be to fit a 19mm swaybar on a base FIT, where there is none.
I think I'll probably make the jump in few months. The base FIT feels a bit like a balloon sometimes. Upgrading the swaybar on my Ralliart was the best suspension mod I did.
Old Apr 24, 2012 | 11:03 PM
Chitownfit's Avatar
Progress bar all the way. Take it for a spirited drive before and then after. As soon as you hit your first turn after it's on you'll notice a huge difference. I recommend you check the bolts every so often the first few trips you take just to make sure they don't loosen up on ya.
Old Apr 25, 2012 | 08:42 AM
spookyneo's Avatar
What are the steps to install the swaybar on a base ? Is it only to bolt everything ? Looking at the Progress website pictures, it seems to be only 6 bolts and that's about it. Since the base does not have any OEM swaybar, is there anything else to do other than bolting the new swaybar ? If so, it seems to be a very easy install...
Old Apr 25, 2012 | 03:12 PM
feared's Avatar
it just bolts right up. same install for both sport and base
Old Apr 25, 2012 | 03:26 PM
spookyneo's Avatar
Thank you feared. I came across the DIY for the Progress right before you answer my post. It seems very easy to do
Mikeyk12
Jan 22, 2013 11:01 AM
jcalhoun
May 18, 2012 04:59 PM
Chad T
Apr 13, 2012 09:34 AM
ej96hatch
17
Dec 19, 2010 09:29 AM
cargun
Nov 3, 2009 04:25 AM
