Recommendation on lowering spring
Old Jul 17, 2012 | 02:50 AM
GE8_typeR's Avatar
Exclamation Recommendation on lowering spring
Hi everyone,
I just purchased a new Orange Metallic 2011fit sport and am looking to upgrade my suspension. I'm not looking to go full coilovers at this time. Based on researching and looking at all the pics on the forum, I've narrowed my choices down to tein s tech or eibach sportline.
Any have experience using both springs and can give some input on which might be better?
Am also running on 16x8.25 + 15 offset wheels W/ 205/40/16 Tires
Thanks in advance!
Old Jul 17, 2012 | 11:28 AM
Wanderer.'s Avatar
I have S-Techs and i'd be scared running them with such aggressive wheels simply because the S-Techs are not stiff springs, and the body leans some in turns (rub rub rub). The fact that there are no aftermarket stiffer dampers available compounds the problem. You will have some fender gap with 16s and 40 series tires + S-Techs, if you're going for the "flush look", they will not accomplish that very well.
I'd probably save up for coilovers if I were you, or run a less aggressive wheel setup.
Don't get me wrong, they're fairly comfortable springs for the drop they give you, but they're not sporty at all.
Old Jul 17, 2012 | 11:55 AM
eurobeaner's Avatar
+15 is too much. +25 is much better in a 8.25. That's what mine are. 17x8.25 +25
Old Jul 17, 2012 | 01:50 PM
zilla8's Avatar
Congrats on your new Fit.
I would recommend Swift springs above all others but it looks like you are going for a certain look/stance
I think you may rub with that wheel/tire combo with either of those springs.
Did you consider any of the Tanabe springs like the DF210?
I know I hate to spend more money changing things but you really like to get it right the first time.
If you plan on keeping your current set up I would save up for coils.
Old Jul 17, 2012 | 08:16 PM
ThEvil0nE's Avatar
fender roll + fender pull + camber bolts up front will be your option to fit those wheels.
Old Jul 18, 2012 | 03:36 AM
GE8_typeR's Avatar
Thanks you guys for the feedbacks ..
@zilla8 I was considering the Tanabe DF210 or T1R Springs .,
mo-FUK
Aug 12, 2012 09:59 PM
Java^FiT
Jan 17, 2011 02:42 PM
j6kwok
Oct 9, 2010 07:53 PM
mangberto
Jul 2, 2010 09:41 PM
joshua27
Nov 4, 2007 05:34 PM
