Question for slammed GE8s
Old Oct 2, 2012 | 10:36 PM
TheDilweed's Avatar
i'm planning on buying buddy clubs soon so i can dump mine. i'm just wondering if you guys needed to buy aftermarket parts to fix your alignment. i'm running -2 degrees camber in the fronts with eibach camber bolts and -1 degree in the back.
however, my thrust angle is suffering. my rear right's toe is out of spec. did you guys experience this after dropping your car?
basically, i just wanna know what parts you guys recommend so that i'll be able to dump my car. let me share with you what i did so far.
- on the lowest setting on my apexi n1 exv coilovers, with 1 perch removed on each strut and shock.
- eibach camber bolts maxed out
- 17x7.5 +35 rims with 205/40 tires
- all fenders rolled and pulled
i hope i made sense and you guys are able to help me! if you need me to clarify anything, let me know. THANKS!
tougerunner86
23
Apr 19, 2016 07:16 PM
Nvillegas
Jan 9, 2014 01:05 AM
Green karma
19
Jan 8, 2013 11:53 AM
BlueBoogers
Apr 20, 2012 10:42 PM
Illmatic07
20
Jun 12, 2009 04:16 PM
