Christmas comes early. Redshifts Koni/Groundcontrol Coilovers
Old Jun 22, 2013 | 02:44 PM
  #81
solbrothers's Avatar
set camber to as negative as possible IMO.
Old Jun 22, 2013 | 02:59 PM
  #82
cjecpa's Avatar
Thanks will do
Old Jun 24, 2013 | 10:26 AM
  #83
RedShiftChris's Avatar
so does the front redshift koni mount on a GD? I'm ready to pull the trigger but chris hasn't gotten back to my message in a few days.
oops...sorry about that. Not sure what message I didn't get back to. was is a pm? Anyway, it will fit the GD except that the brake line brackets at the bottom are for the GE and not the GD; so you will have to do some to tie the brake lines up (like zip tie) because they won't fit the GD clips.
Chris
Old Jun 24, 2013 | 04:41 PM
  #84
Just ordered a set from redshift
Old Jun 24, 2013 | 08:14 PM
  #85
TPColgett's Avatar
Sweet.... so much Fit + Koni goodness
I always encourage front toe set to zero... but that is my preference. At the LEAST make sure it is within spec.
If the camber bolt is in the top hole, expect -1 to -1.5 depending on the alignment shop. IF they put it in the bottom hole they can get -1.8 or more
Old Jun 24, 2013 | 08:23 PM
  #86
..... if it's a serious autocross car, run 1/8" toe out in front. It will turn better.
Chris
Old Jun 26, 2013 | 02:11 AM
  #87
fitNasty's Avatar
Just got back from a great turn around trip from Vegas. Total miles logged since the install is roughly 1000 miles. And from my personal experience compared to my previous setup with T1Rs springs, I would give Redshifts setup a 8.5 out of 10. Please note that my rating is also base on my current settings and condition of my tires (which is due for a new set). The car rode smooth throughout the Vegas roads but does has it slight rough bumps due to the lovely condition of L.A freeways. But still a major improvement to the T1Rs. The rebound on the Konis are very noticeable. Before I wouldn’t dare take the car out on a long trip w/o my stocks rims and tires. And to feel like I was on stock since the install, speaks volumes of RedShift's coilovers. Cant wait to feel the improvements once I tinker around with the konis a bit more with definitely a new set of tires.
Old Jun 26, 2013 | 11:00 AM
  #88
LDB's Avatar
LDB
Man, those are so good looking it's a shame to hide them in the car. They should be in a nice frame on the wall for everyone to admire how great looking they are.
Old Jun 26, 2013 | 11:40 AM
  #89
What are your springrates? Ride height?
Old Jun 26, 2013 | 01:25 PM
  #90
TPColgett's Avatar
From page 1:
love me some comfy ride. went with a low 280/224 (5k F/4k R).
From page 2:
Fairly soft springs for how low he is... AND if it still is comfy on the GE... You may have a little less stroke on the GD, but stiffer springs will help. I'd go at least 6K/8K on a GD... softer chassis and all.. For you Sol to be super low in the rear, might have to go to 8K/10K like my race setup.... I wouldn't go higher than 12.5K in the rear as that's at the upper limit of what a Koni Yellow is valved for.
Old Jun 26, 2013 | 02:16 PM
  #91
I ordered 500f 600r.
Those rates are way too low for his height. He is possibly bottoming out those shocks.
Old Jun 26, 2013 | 02:17 PM
  #92
Actually, I was almost tucking rim on those rates and it lasted 40k miles.
Old Jun 26, 2013 | 02:19 PM
  #93
TPColgett's Avatar
Sounds good
I would be watching the bump stops that's FOR SURE... BUT, the shocks provided are essentially "short" shocks for a GE chassis... Kinda like how the Skunk2 ProC's were short for the GD. Like I said, I'd be testing those bump stops... but it may be OK
Old Jun 26, 2013 | 03:56 PM
  #94
cjecpa's Avatar
I got the rear shocks only last Friday. Saturday I went full soft setting much better for the roads around here. The car does not feel as jumpy as with the stock shocks and my Eibach Prokit springs. Actually notice the improved difference in ride quality. As for shorter shocks Chris did tell me to put the jack under the shock to get it in place, which I did. Also have gone over a few speed bumps (cutting through the back of Walmart) no problems.
Would be interesting if Koni starts producing the fronts for the Fit to see if there would be any additional improvement in handling and ride.
Old Jun 26, 2013 | 04:03 PM
  #95
TPColgett's Avatar
I JUST got my FedEx tracking confirmation that my rears are waiting for me when I get home Will have them on the car for several days of commute and a cruise to a Fit meet, then put them to work Sun at an AutoX
Sol, I will be MORE than happy to compare with you in person Sunday
Old Jun 26, 2013 | 05:39 PM
  #96
Sunday?? You mean saturday???????
Also I know how awesome koni shocks are. Thats why I'm so happy this setup cane out.
Old Jun 26, 2013 | 05:44 PM
  #97
TPColgett's Avatar
Yep yep, SAT. I can show you shimz too There will also be a GE at the meetup with Koni rears!
Old Jun 26, 2013 | 05:59 PM
  #98
Old Jun 26, 2013 | 06:00 PM
  #99
Yes show me shims!
Old Jun 26, 2013 | 06:08 PM
  #100
Wanderer.'s Avatar
Originally Posted by zilla8
Well maybe absolute was not reached and I have no idea if inside wheel lifted, but lets just say I've pushed it about as hard as you should
outside of a closed course track
Is that Stunt before the overlook?
