16x8 rims with swift springs
Old Aug 8, 2013 | 10:58 AM
13fitrr's Avatar
Hi I'm new, long time reader, first time poster. I want to get some of these esm 002 rims. 16x8 with 20 offset. I currently have swift spring on the car. Will this set up work or will I end up spending a lot of money on modifications to make this set up work. I plan on getting 205-45-16. Will this set up rub? I appreciate all your help from the fit gods. Also I have search the forums many times for this question. Thanks
Old Aug 8, 2013 | 11:43 AM
onetwothree's Avatar
Roll your guards and slight pull
Old Aug 8, 2013 | 12:35 PM
13fitrr's Avatar
Do you know how this set up will ride?
Old Aug 8, 2013 | 05:59 PM
I've got 15x7 +20, lowered on tein and rubbed in rears with full load so I rolled. Front I haven't rolled but only rub on big bumps when I go fast, 16x8 +20 should be a little worse
Old Aug 8, 2013 | 06:30 PM
13fitrr's Avatar
Oh ok. What size tires do you have?
Old Aug 8, 2013 | 09:29 PM
running 185/60 to fill up my guards and little stretch
Old Aug 9, 2013 | 12:02 AM
13fitrr's Avatar
60 wow. Does anybody know any good place to have my fenders pulled and stretched, in so cal?
Old Aug 9, 2013 | 01:48 AM
1SickVeilsideZ's Avatar
I keep seeing these threads pop up with people wanting to run 16X8 +20 offset so here is a pic of my fit with my work wheels with those specs so you guys know what you're in for. You will need to roll and pull your rear fenders in order to fit.
Old Aug 9, 2013 | 02:02 AM
13fitrr's Avatar
Can you post more pics with different angles?. Thanks in advanced
Old Aug 9, 2013 | 04:06 AM
Rears are easy, fronts need camber bolts
Old Aug 9, 2013 | 06:26 AM
singhonwheels's Avatar
i have seen this setup on ff.net
IMHO the fender tire gap does not look good with this setup .
you need to lower more to run this setup, preferably coilovers.
check out johnnypaseo.
https://www.fitfreak.net/forums/fit-...ad-pics-5.html
Old Aug 11, 2013 | 12:19 AM
13fitrr's Avatar
Here's a pic of my current set up on swifts
Old Aug 11, 2013 | 12:21 PM
zilla8's Avatar
It's funny how other small cars can fit 9" wheels with no problem because of the design of the fenders.
The Mazda 2 guys are running 15x9 without pulling or rolling fenders but it's because of all that room under the fenders.I bet our cars would look great with some 15x9 6ul's
Old Aug 11, 2013 | 12:24 PM
13fitrr's Avatar
Agreed, that looks good
Old Aug 13, 2013 | 11:49 PM
13fitrr's Avatar
Anymore information before i take the plunge?
RODSFIT
13
Jun 5, 2011 05:10 PM
xonexlifex
13
Mar 6, 2011 04:16 PM
i dnt f!t
Mar 3, 2009 04:29 PM
NBPturtle
May 15, 2008 09:08 PM
Raymond87
Dec 19, 2007 06:08 PM
