Got -1.8 camber just from 1 SPC bolt only!
Old Aug 14, 2013 | 07:59 PM
bluesaint's Avatar
So was reading on the forum and noticed most folks complained using only a single SPC camber bolt the most they were able to get was around -1.0 camber.
So shockingly, my alignment shop told me they were able to get -1.8 up fronts with no problems at all with just swapping out a single strut bolt with the SPC.
My info:
2013 GE8 Base
swift springs
Progressive RSB
15x7 RPF1 w/ 205/50/15 BFG Rivals
So wonder what all the fuss was about needing two SPC bolts to get anywhere near -2.0?
Old Aug 14, 2013 | 08:04 PM
13fit's Avatar
They probably did the bottom bolt. Having the camber bolt up top is best for most angle
Old Aug 14, 2013 | 08:11 PM
Wanderer.'s Avatar
Nah ya got it wrong.
1.75 degress was the reported with one bolt.
~2.5 degrees was with two bolts.
Some people are running 1 degree with one bolt and not maxing them out.
Glad you got them in though, will be ordering mine tomorrow.
Old Aug 14, 2013 | 11:11 PM
singhonwheels's Avatar
i was wondering where could you get the max negative camber with bolts?
on the upper side of the strut or the lower ? or is it the same ?
Nvillegas
Jan 10, 2014 02:28 PM
Green karma
19
Jan 8, 2013 11:53 AM
Wafulz
Dec 13, 2012 07:54 PM
BakedCookies
Nov 7, 2012 04:27 PM
Spooling
Oct 9, 2008 02:23 PM
