Review: Tein Street Basis Coilovers
Old Dec 12, 2018 | 11:28 PM
GE82010's Avatar
so now you know what to look out for
moving forward.... always ask for ACTUAL pics of the item .... done deal
thanks im so hyped i finally going to see her lowered
Old Dec 13, 2018 | 04:43 PM
evilchargerfan's Avatar
if you can ... the model up, gives you the ability to adjuster damper. if the price jump isnt too much, its worthwhile (imo)
Old Jan 14, 2019 | 02:11 AM
Keali'i Pomaika'i's Avatar
How low is it lowered fully?
Old Mar 8, 2019 | 05:17 AM
GE82010's Avatar
I just order some of these 🙂 my question is is the car going to have any negative camber do I need camber plates at all or just install those coils and get it align and I’m set to go?
Old Mar 8, 2019 | 12:59 PM
that info is easily found on tein's webpage
no plates. camber bolts = front. camber shims = rear
(check my FS thread, I have a spare set of bolts avail)
Old Mar 8, 2019 | 01:38 PM
GE82010's Avatar
Message sent charger
Old Mar 12, 2019 | 10:55 PM
GE82010's Avatar
So I’m going to install these tomorrow does these come pre set already and did u guys lower the back more then the front? Would appreciate. If u give me a bit of info about how to set it up
Old Mar 13, 2019 | 03:08 PM
they do not come preset
however, tein provides EXCELLENT instructions. be sure to set it up, exactly as the manual specifies
as far as lowering hte back more, gk5 people will naturally have that look, as oem gk rear suspension components are longer and would give that effect of being "lower"
bit of info about how to set it up = read that tein manual, like read it 2x or 3x, really get a feel for what they want you to do. I did post up pics in my thread, about how I set it up (ie, i simply followed teh manual)
Old Mar 13, 2019 | 03:47 PM
GolNat's Avatar
Just set the height to what looks good to you. No one looking at the car is going to get a tape measure out and make sure the front is even with the back. I made mine look even but if you measured it was not. It took me a few days of tweaking here and there to get it how I liked it.
The manual they provide is very nice like Evil said. Just read it a few times and get all your measurements set before starting to install them.
Old Mar 13, 2019 | 04:32 PM
GE82010's Avatar
Thank u guys as I’ve been having problems one of the strut the thread wasn’t right had to rethread it and got one install but as soon as I tried taking off my second wheel my lock for the lugnuts cracked 😢 so I just went out to eat I’m not as hyped right now but I know these problems happend
Old Mar 13, 2019 | 10:26 PM
GE82010's Avatar
Finish them besides some hicups but they ride so smooth I’m close to where I want it lowered but overal they are nice I think that’s the touch my car needed
Old Mar 13, 2019 | 11:13 PM
  #32
GolNat's Avatar
Good deal.
Old Mar 14, 2019 | 12:03 AM
  #33
GE82010's Avatar
Still needed put the cap on my rims but the ground is in even but soon taking it to my buddy’s house love it tho
Old Mar 14, 2019 | 12:09 PM
  #34
lookin good!
over time, you may find yourself wanting to experiment with diff ride heights. have some fun with that. I ended up, going max low (within tein's recommend of course, which I believe was -2.4 in?) to clarify, not ALL THEY WAY low, which I think is -3 in, that'd be crazy.
I also played around with damper, 2 clicks softer, 4 clicks softer, 2 clicks harder .... and long story short, I put it back to tein's recommend as I felt that it was the best for comfort, and performance (too soft degraded performanced/introduced some body roll, and I did not like that, and too hard was simply ... too hard/not comfy)
Old Mar 14, 2019 | 11:53 PM
  #35
GE82010's Avatar
I love this suspension should of done this long time ago while I had the everything removed double checked on spark plugs they are still nice n tight yay 😃
After she’s washed up
Old Sep 9, 2021 | 05:08 PM
  #36
Greg09base's Avatar
I just got a set of these and the manual says to adjust the front and rear to 1.4” and 1.7” of thread showing. I’m assuming that will put you at the base 1.4” setting but not sure. Can anyone confirm this?
Old Sep 10, 2021 | 12:33 AM
  #37
eulogy's Avatar
They max at 2.6" front and 2.4" rear...so in theory u should have about 1" of thread under the bottom locknut. But their 1.4 and 1.7 seem accurate considering sag from the cars weight.
AtticusFit
Mar 12, 2011 04:51 PM
its.ryu
37
Aug 30, 2010 06:53 PM
nilly1010
May 23, 2010 11:33 PM
YeeFit
May 26, 2008 12:41 PM
Mynute 1
Jul 21, 2007 09:52 PM
