Cure for understeer?
Old Mar 3, 2016 | 03:52 PM
F..it's Avatar
Have you guys come up with a solution for the horrible understeer these cars have?
AC
Old Mar 3, 2016 | 04:38 PM
TPColgett's Avatar
Sure, get an alignment with camber bolts for at least -1.5 of camber. Get higher performance lower tread wear tires.
You can go into additional suspension work after that.... The added on progress rear "sway bar" is a great choice.
Old Mar 3, 2016 | 05:18 PM
dwtaylorpdx's Avatar
Make your rear tire pressure higher than the front, I run 3 lbs higher in the rear.. But mine is a GD sport with a rear factory sway bar. I have a Hatchback RWD BMW that requires this out of the box, factory front tire pressure is 28 rear is 34. If you don't run the split the bugger is a scary B**ch to drive. Just set your pressure on cold tires and add a lb and test until you find the sweet spot. Usually its 6 lbs or less. (Tires matter... too...)
Old Mar 8, 2016 | 12:05 AM
Desmond Lamar MacRae's Avatar
Or get a bigger anti roll bar $200 max or 10mm spacers $50 max. That's what I'll start doing before rear sway bar.
Old Mar 8, 2016 | 03:05 AM
wzlfit's Avatar
If you are adjustable there is useful info on this in the gd suspension section in the sticky thread "suspension theory".
Old Mar 9, 2016 | 12:31 AM
Stiffening the front without the back usually results in more under-steer.
Tire pressure is free and it will make a difference.. although smaller than a sway bar..
FWIW my 07 really doesn't under-steer till your passing the limit.. But then its a little late.. And I'm running pretty thin tires right now..
Old Mar 9, 2016 | 06:54 PM
Osubeaver's Avatar
Agree with this. You'd be surprised how much tire pressure can help before any other mods.
What scenario are you experiencing understeer though? An auto-x setup vs. track setup vs. a street setup is going to be very different. Do you have any current suspension modifications? What are your current tires?
cargun
Nov 3, 2009 04:25 AM
benmunger
May 16, 2009 02:30 PM
slip
Apr 29, 2008 04:52 PM
FELIXY69
13
Jan 10, 2008 10:46 PM
kkim
18
May 25, 2006 10:55 PM
