Bolt on the shock keeps spinning
Old Jun 14, 2018 | 01:31 AM
perkidddoh's Avatar
I recently lowered my car on swift springs using the stocks shocks and when it was time to install them back, the bolt that holds down the springs on the shocks just keep on spinning away. I know that there is a black piece right under it that has bearings inside, could it be that this is spinning the bolt and not really tightening the springs down?
Any advice would be greatly appreciated.
Old Jun 14, 2018 | 11:42 AM
vtecfit1's Avatar
I believe you need a pneumatic gun to turn it fast enough to tighten, if you are using a pneumatic gun and it still spins you might need a new put an allen (sp) in the top of the strut and use a wrench to tighten that nut
hope we are talking about the same thing
Old Jun 14, 2018 | 11:47 AM
perkidddoh's Avatar
We used an impact drill from what I remembered and it just kept spinning. We tried using a wrench but without an allen key.
It might be that we didn't use an allen key to hold it down from moving around.
Thanks!
Old Jun 14, 2018 | 01:40 PM
perkidddoh's Avatar
Just to be specific and avoid confusion, I am referring to number 20 on this diagram and not 18.
Old Jun 15, 2018 | 09:09 PM
xxryu139xx's Avatar
are the springs compressed when you are doing this?
Old Jun 15, 2018 | 09:31 PM
perkidddoh's Avatar
the swift springs are slightly compressed from the nut being tightened but not compressed with a spring compressor tool.
The main reason why I am asking is because I am afraid it might have loosened itself but steering is straight and it turns normally. I just hear this popping noise AFTER a speed bump.
BUT I am thinking now that it is something else, like a the swaybar endlink because I felt this vibration and noise after going through a steep speed bump that traveled from the center of the car to the passenger side (where the noise is coming from). Possibly that the sway bar is binding.
Old Jun 15, 2018 | 10:21 PM
xxryu139xx's Avatar
did u install 3-13 correctly?
Old Jun 15, 2018 | 11:50 PM
perkidddoh's Avatar
yes. All those where installed correctly. I also made sure they weren’t loose at all miles after driving around.
The noise is like a very rubbery almost hollow popping noise. Almost the sound when you hit a pothole very fast when going normal speed on a speed bump.
I am assuming it is the endlink because of the prior reason when I felt the vibration from under traveling from the centee of the car to the passenger side.
Old Jun 27, 2018 | 05:03 PM
evilchargerfan's Avatar
have a friend slide down the dust cover, and grip the shaft
using an impact gun, spin the crap out of bolt 20
(compress the springs, if needed)
apexanimal
Mar 23, 2014 02:45 PM
Rster85
Sep 8, 2013 10:50 PM
Unreal12
Mar 29, 2012 11:19 AM
Kuturagi
Mar 29, 2012 04:25 AM
dewthedew
24
Nov 21, 2008 01:21 AM
