What 205s won't hurt my mileage?
Old Sep 25, 2009 | 04:59 PM
runbikerun's Avatar
I don't know if it is possible but are there any 205 width tires available that won't hurt the mileage on my 09 sport?
I have stock 16s right now.
Thanks
Old Sep 25, 2009 | 05:19 PM
redrumm's Avatar
any reason on the change? just wanna go wider?
anything other than stock will throw off your speedo not really sure if it will hurt your MPG's though. im sure if you have a light foot then you should be ok
Old Sep 25, 2009 | 05:29 PM
billmus86's Avatar
My Lips Bigger!
just drive it.
mpg changes dont matter,
its a fit for christmas sake!
hehe
Old Sep 25, 2009 | 06:07 PM
stevet47's Avatar
When you choose a tire look for a low rolling resistance, light weight, and harder compound. That will help offset the loss from the wider tire.
If you are looking for a summer tire, the General Exclaim UHP looks like a pretty good choice.
Also, inflate to max sidewall pressure (or at least higher than placard). It is a hot topic, but people who have actually done testing know that hydroplaning is reduced, cornering stability is increased, tread life is increased, and of course mpg is increased.
Old Sep 25, 2009 | 06:19 PM
Import Al's Avatar
All good suggestions except the recommendation for General Exclaim UHPs. I've run these recently on my '93 Civic EX coupe in 205/50/15 on lightweight wheels & they just had too much sidewall flex for an enthusiast like myself.
Overall they're a good value & have good treadwear, but I'd choose Falken Ziex 912's, practically any Yokohama & most BFG's for a few more $$$ over the Generals just because of their softer sidewalls.. it had a noticeable effect on initial steering/handling response; crisp steering is one of the Fit's best attributes & Exclaim UHP's don't highlight it as well as other tires in their price range.
Old Sep 25, 2009 | 07:20 PM
stevet47's Avatar
Good to know.
I just meant it was good based on the specs.
Old Sep 25, 2009 | 08:47 PM
Stravos's Avatar
Wider tires shouldn't throw off the speedo... As long as you keep the same outer diameter it should be fine.
Old Sep 25, 2009 | 09:01 PM
runbikerun's Avatar
I was trying to smooth out the ride and hopefully improve the handling. I thought maybe the goodyear fuel max would be an option but I can't really get an reviews on handling.
Old Sep 25, 2009 | 09:47 PM
redrumm's Avatar
When speedometer reads 60mph (96.6km/h) actual speed will be 59.2mph (95.3km/h): 1.3% slower.
http://www.rims-n-tires.com/rt_specs.jsp
Old Sep 25, 2009 | 09:51 PM
kelsodeez's Avatar
UNBANABLE
if u want to gain mileage get 15 in. wheels. if you want it to stay the same, dont change your wheels.
Old Sep 25, 2009 | 10:46 PM
stevet47's Avatar
He could get lighter than stock 16s, or even 17s and still gain mpg. No need to compromise looks/handling by going with 15s unless absolute max mpg gain is the goal.
Old Sep 26, 2009 | 01:25 AM
billmus86's Avatar
My Lips Bigger!
unsubscribed.
Madasadad
Apr 19, 2013 06:16 PM
billtmore
Apr 26, 2011 11:56 AM
Bryan-Guy-Status
Jun 18, 2009 10:21 PM
OrangeRevolution
Car Shows, Events, and Racing
Apr 20, 2009 09:43 PM
TurnOnTrance
Jul 5, 2008 01:45 PM
