will this fit?
Old 01-07-2011, 01:00 PM
aqua-holic's Avatar
will this fit?
hallo i'm new here and i'm from holland,
i bought a new honda jazz (fit) but i was wondering if the rims would fit?
í found some wheels in the sizes 7x 17 4x100 ET 30
i've got stock springs
would this fit?
Old 01-07-2011, 01:08 PM
Perrenoud Fit's Avatar
What do you think Hootie?
Is the 30 = 30mm offset? if so it's going to be tight to the disc brakes.
Hootie is a member here and is a good source for offset.
Old 01-07-2011, 01:28 PM
aqua-holic's Avatar
I dont know? In holland the call it 'ET' but i'm not sure if the offset is the same thing?
Old 01-07-2011, 11:05 PM
j1nNju1c3's Avatar
Yes ET and offset are the same thing
Old 01-12-2011, 12:09 AM
slp950's Avatar
No, it will not close to the disc brakes. Offset has NO relation to how close the brakes will be in proximity to the spokes. the face profile does, which is why companies like Work offer different faces or "disks" which change how the spokes curve or straighten to clear brakes or give deeper lips.
There is a guy on here TGIJoseph who ran 17x7 et28 in the front and 17x7 et30 rear, so yes 17x7 et30 will work. However, your tire will protrude slightly from the fender, possibly causing rub and or damage if you hit a bump while cornering. It will also look a bit silly.
Here's a pic of his for reference:
His is lowered quite a bit, which is why it doesn't look silly.
Old 01-12-2011, 12:25 AM
aqua-holic's Avatar
Okay thanks,et 38 would that be okay? and does that rub?
Old 01-12-2011, 09:41 PM
slp950's Avatar
7" wide with et42 is recommend, but you can run et 38 without any issues. Just run a 205/40-17 tire and you should be just fine!
wackyflik
05-29-2012 09:04 AM
Chikubi
23
03-30-2009 10:13 AM
sbualuba
01-31-2009 02:04 PM
KnifeEdge_2K1
12-26-2007 11:09 PM
J.P.
02-21-2007 01:48 AM
Quick Reply: will this fit?
