Rubbing question
Old Jan 30, 2012 | 04:09 PM
Badwrench's Avatar
Rubbing question
I am looking at some wheels that are 18x8 +35 offset with 215/35 tires (same outside diameter as stock).
My question is: How bad would these rub (I know they will, but want to know if anyone else is running something similar)? I am running Tein springs (roughly 2" drop). I don't have a problem rolling the fenders a touch to get the lip smooth, but would rather not push them out.
Old Mar 5, 2012 | 04:46 PM
Miike's Avatar
If you are looking for good fitment with a drop like that I would roll my fenders regardless. I would get a camber kit as well so you can manipulate it to where you won't rub going straight or turning. Also if you plan on going lower... like for example, you get an adjustable coilover suspension dampener setup, your fenders will be rolled already so you wouldn't have to worry about it anymore. It's really to each it's own. A lot of people want to have a good fitment these days and just get wheel specs everybody else is using. If you want to do it the right way, take actual measurements on how much wheel well space you have and utilize to your choosing. Hope this reply helps.
Old Mar 8, 2012 | 08:38 PM
slp950's Avatar
I had 18x8 et45 (with 8mm spacers in rear) with 225/35-18's and it rubbed on dips and bumps like crazy crazy. Your setup will be 10mm further pushed out and only 5mm less width on either side of centerline of the tire. Effectively you will have 5mm less clearance than I did and line rubbed a good but just in lowering springs. I did not roll the fenders or pull them.
Old Mar 8, 2012 | 09:08 PM
Badwrench's Avatar
I figured as much. I tried them on (without driving it), and you could see that it was basically going to rub all the time. I would've had to pull the fenders about an inch just to clear. Way too big for the Fit
Old Mar 9, 2012 | 04:47 PM
Miike's Avatar
This is why i said what i said on my previous post bro. Sorry they didn't fit.
Old Mar 9, 2012 | 05:14 PM
Badwrench's Avatar
No biggie. Was just a killer deal on some wheels and tires - 4 Axis Decade 18x8 +35 4x100 with almost new toyo proxes for $400.
These:
nsxfit
13
Feb 23, 2020 12:32 AM
FitMinister
Mar 6, 2015 01:14 PM
bowtech83
Aug 11, 2012 02:09 PM
tougerunner86
Apr 10, 2008 02:12 AM
Reinert79
Mar 22, 2008 05:14 AM
