3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Blanks on Dashboard - 2019
Old Mar 17, 2019 | 10:27 AM
SilverEX15's Avatar
Have any of you removed either of the 1" x 1/2" blanks to the left of the steering column on a 2019 Fit? I want to put the switch for heated seats in one of those spots, but the blank isn't popping off easily, and I don't want to scratch the dash. I removed all three of mine on my 2015, and I don't recall it being a problem. I don't think I'll be able to get behind it and push it out.
Old Mar 17, 2019 | 12:06 PM
Action Jackson's Avatar
If the '19 is the same as my '16, you can also try to reach underneath and push it out.
Or there is a side cover to the left that you can remove after you've removed part of the rubber trim. There is a screw there that you can remove. Then you can pull out the dash a bit to get at stuff.
Old Mar 17, 2019 | 12:19 PM
SilverEX15's Avatar
Thanks! Yeah, I forgot about that side panel. I'd like to get the switch in place because working on that won't interfere with driving the car. When I remove the seat, driving it will be a challenge. : )
EDIT: I think I'll save myself some unnecessary work and drill through that bank while it's attached to the dash. The switch is small and round, and I think it will fit right inside that blank. If it doesn't, I'll pop the blank out and use a different switch.
Old Apr 2, 2019 | 12:06 PM
kryptonite0106's Avatar
I know it might be a little late, but the blank isn't completely open on the back. I had to dremel out the back a little in order to fit a small button momentary switch.
The blank was a bit hard to pry out from the front, but if you wiggle in a trim removal tool on the top and bottom, it'll eventually pop out.
Old Apr 2, 2019 | 12:46 PM
SilverEX15's Avatar
Thanks. I think I'll remove it with a plastic tool. From what I remember, removing them on my 2015 wasn't difficult..
widg
Dec 13, 2022 02:26 AM
SilverEX15
Oct 30, 2019 02:44 PM
sillypuddy
Jul 29, 2019 04:44 AM
dwtaylorpdx
Jul 3, 2016 10:08 PM
polokid69
Oct 26, 2009 03:15 PM
