3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Creative solutions for armrest?
Old Jan 30, 2015 | 08:01 AM
MacStevenXIII's Avatar
Originally Posted by korgster
I just posted this in another thread but it best fits here:
So far, until I can purchase an OEM product, I think the solution for me will be a variation of the "curtain rod prop" solution. I'm short so the armrest doesn't need to be opened much to provide proper support. Raised slightly at a low angle (armrest opened) I can rest my elbow on the front portion and rest my hand on the shifter (auto transmission). Same principle as the curtain rod solution.
Since I don't like the look of the curtain rod, I'll be looking to create a small block which looks like at "T" with a fat bottom. Perhaps use black packing material some times found in computer shipping boxes (hard foam) which would be easily carved to shape. The idea is to prop open the armrest with it. When not in use, it could be dropped into the compartment... or simply left in place.
Thoughts?
You could stop into a craft store, a Michael's or AC Moore, and buy that hard foam to carve.
I like the idea of the curtain rod because you can pop it out of sight when you're not driving so and I keep stuff in my center console so your idea wouldn't necessarily work for me but if you don't keep too much in there then it sounds like a good solution for you for now.
Old Jan 30, 2015 | 09:08 AM
korgster's Avatar
Thanks for the craft store lead. I'll check it out this weekend.
You're right, I don't expect to use the cavity for much. I think the "block" will feel more solid than the stick method. It won't cost much to try this approach.
I'll report back here when I've tried it.
Old Jan 30, 2015 | 11:00 AM
tbFit's Avatar
Smile My hand crafted arm and elbow rests
Speaking of craft stores, I went to Jo-Ann and bought some black micro suede fabric and made my own. The fabric was $8 for a yard.
I used left over foam board from my cargo cover project and also picked up some additional 6mm foam to provide a non-slip service for mating against the existing armrest.
Here is the final result, very snug and comfortable.
For attachment to the armrest, I used 5 cable wraps sandwiched in between two 13x5 inch foam boards and hot glued along with that 6mm foam for non-slip and extra cushioning.
I also made a matching soft elbow rest that stays in place with a piece of plastic hot glued to the removable rest and wedged into the existing cloth/plastic seam:
If you are not inclined to do the crafting of the center armrest yourself, I was very tempted to spend $14 and get this item:
http://www.ebay.com/itm/WalterDrake-Car-Armrest-Cushion-Black-SM-/221648552149?pt=LH_DefaultDomain_0&hash=item339b4880d5
which looks to be the same size and shape. However, I would have augmented their version with some foam board on the bottom to stiffen it up for the overhang as I did in my hand crafted version. I don't think it would have stayed in place as well, but for $14, it might have been good enough and done the trick.
I still need to make a passenger side elbow rest, but for now, I'm a happy driver with the mod!
Old Jan 30, 2015 | 02:37 PM
Fitster C.'s Avatar
Looks good and comfortable. I'm not sure, but I think the absence of an easily reached arm rest may be keeping my hands on the wheel, but I will re-assess after a long (2-day) drive later this year.
Old Jan 30, 2015 | 02:48 PM
korgster's Avatar
Thanks for sharing tbFit. Nice of you to post the pics. You did a good job and I do like your clever way of securing it. Including wrapping the narrower front part of the armrest. Looks secure.
Old Jan 30, 2015 | 03:04 PM
Looks great! Thanks for posting pics and I'm really diggin the cable strap idea. I think I'll be stopping into my local craft store to make one.
Old Jan 31, 2015 | 10:57 AM
korgster's Avatar
tbfit,
what did you use as the core of your "good lookin' "armrest?
Old Jan 31, 2015 | 05:53 PM
tbFit's Avatar
tbfit,
I used some existing 1.5" foam that I had in the garage, cut to shape and 2 layers of foam board and 1 layer of 6mm hi density foam. I also trimmed (beveled) all the corners after taking the photo.
Jo-Ann fabrics has foam chunks as well if you need them, but I think my own foam seemed denser.
I used this long Olfa 25mm wide knife to make all the large foam cuts and it sliced it like butter, highly recommended:
OLFA 5006 H-1 25mm Rubber Inset Grip EHD Utility Knife OLFA 5006 H-1 25mm Rubber Inset Grip EHD Utility Knife
Here is the fabric I used, $8.00/yard:
Signature Series Home Decor Solid Fabric Suede-Black - Item # 7951106
And the 6mm foam, which is actually $1.49 for a sheet:
Darice Foamies Foam Sheets - Item # xprd1023089
Old Feb 1, 2015 | 08:56 AM
korgster's Avatar
Lightbulb Temporary Fit 2015 DIY armrest
Thanks tbfit. That's great!
Until I can get the materials and work this out, I've come up with my super cheap not-so-elegant-but-it-will-do solution. It's based on the curtain rod solution... the "prop".
I used a 12" rigid cardboard tube we had lying around from a stretch and Seal box.
I had to squish one end in order to fit it snugly into the the narrow armrest top cavity.
Here's a link to the album of the pics (If there is an easy method of embedding a FitFreak album here, please share )
Temporary Fit 2015 DIY armrest prop - Picture
Old Feb 12, 2015 | 12:01 PM
James Butler's Avatar
easy armrest
I just bought a 17 inch by 17 inch black pillow case from Ebay for under $3.00 and filled it with pillow stuffing. You can get the pillow case in any color. It is pressed between the seats when needed.
James
Old Feb 12, 2015 | 12:30 PM
korgster's Avatar
Yet another clever idea! - Thanks for sharing.
Old Mar 21, 2015 | 12:36 PM
  #32
korgster's Avatar
For those interested, I built one in the end.
See this post:
https://www.fitfreak.net/forums/3rd-...ml#post1298391
It was inspired by TbFit's solution. Thanks TbFit!
Old Oct 12, 2015 | 11:45 AM
  #33
rose313's Avatar
Generic Arm Rest
I purchased a black generic arm rest on-line. (Installed a similar one on my 2007 Fit.)This one had metal plates to attach to the plastic base. Apparently the plates were supposed to hit the floor bottom of the car it did on the 2007 one. These plates would not do that. I tried xxx ways to use it. Attached ONLY the short piece which fit perfectly over the Fit armrest. Used Duct tape to keep it in place.... pretty tacky! Finally drilled holes in the side of the Fit-rest (Plastic) and bolted the generic one to it. When I open the original armrest, the new generic one is piggy-backing it. Seems like it will work OK now. I make road-trips (have been in all 50 states) and REALLY needed an arm rest that was useful!
Old Oct 14, 2015 | 06:53 PM
  #34
Gorilla's Avatar
Rose313, which one did you purchase and would you mind posting some photos of your setup?
Old Oct 17, 2015 | 10:20 PM
  #35
rose313's Avatar
Gorilla
I purchased (from Amazon) a "Black Leather Center Console Armrest" with a totally worthless 2-cup holder. ($50.99 - by 99 parts).
Have tried to send this xxx times....does not seem to go thru. Will send pics if this works.
Rose313
Old Oct 17, 2015 | 10:27 PM
  #36
rose313's Avatar
Ok...worked this time. Pics not very good due to plastic and mirrored butterfly that I added. This one is not as nice as the last one (on 2007 Fit) but beats the rolled-up towel I was using. Also only 2 bolts on each side....to be painted.
Old Sep 20, 2020 | 02:08 PM
  #37
solidpoint's Avatar
This Yoga balance tool works really well. I like the smoother side up as it has more "tooth" to hold your arm in place, but it makes the console usable for both you and the passenger, and extends well enough over the hand-brake cut-out to provide a really useful arm support. It has to be tucked in a bit, but that's a good thing as it stays where you put it then. Measures 17”L x 9.5”W x 2.4”H. Easy to clean, just take it into the kitchen sink and wash it off. Great for removing doggie drool. Our puppy loves to ride with her head between us when we travel.
It also makes a nice bleacher seat, or butt pad you can put under your bum if changing clothes sitting on the bottom of the door openings. Also a nice knee pad in a pinch if you flat and have to mount the spare tire on the side of the road.
https://www.optp.com/OPTP-Stability-Trainer
... or massively marked up at Amazon....
Amazon Amazon
korgster
Apr 15, 2015 02:26 PM
Ocanler
Jun 23, 2014 11:03 AM
snaithbert
Mar 2, 2013 01:01 AM
caddy365
May 16, 2011 05:17 AM
