3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Led dash switches
Old Feb 5, 2015 | 04:39 PM
James Butler's Avatar
Led dash switches
I wanted to add some switches on the dash for different functions. A member here had found an LED rocker switch on Ebay. It has an LED built in which will turn on when the switch is activated. The switch mounts in a round hole a little under 1/2 inch in diameter. The Fit has three panel switch blanks on the dash. I ordered new blanks from BK Honda for about 85 cents each. I carefully drilled out a hole in the middle and enlarged until the switch would just screw in. That way it would be tight and not need the included nut. Not any room for the nut anyway. I did the rub on letter thing for the legends and sprayed the blank with clear paint before installing the switch in the blank. I then hooked up wires for each switch and snapped the finished switches in place. When I want the function I am ready to hook up the wiring. Here is a picture of the completed switch panel.
Old Feb 5, 2015 | 08:28 PM
Wanderer.'s Avatar
That's pretty cool, nice work. What do you plan to use them for?
Oh wait.
Footwell lighting
Driving lights
Aux power outlet
Haha I was going to do something similar, the GE has little blanks like that too. You should post the link to the switches
Old Feb 6, 2015 | 07:05 AM
n9cv's Avatar
Those switches are also available from Auto Zone and Radio Shack. I have used them for years in automotive applications. Auto Zone has a better selection than RS.
Old Feb 7, 2015 | 08:58 AM
switch link on Ebay
Sorry . Forgot to post the link. They are lots of Ebay sites that have these same switches. They are all about $7.00 to $8.00 for 5 switches. You can pick from red, green, or blue light up LEDs in the switches. Here is the link
http://www.ebay.com/itm/161506583285?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
James
Old Aug 15, 2018 | 11:49 PM
get-fit's Avatar
Talking
[QUOTE=James Butler;1290928]I wanted to add some switches on the dash for different functions. A member here had found an LED rocker switch on Ebay. It has an LED built in which will turn on when the switch is activated. The switch mounts in a round hole a little under 1/2 inch in diameter. The Fit has three panel switch blanks on the dash. I ordered new blanks from BK Honda for about 85 cents each. I carefully drilled out a hole in the middle and enlarged until the switch would just screw in. That way it would be tight and not need the included nut. Not any room for the nut anyway. I did the rub on letter thing for the legends and sprayed the blank with clear paint before installing the switch in the blank. I then hooked up wires for each switch and snapped the finished switches in place. When I want the function I am ready to hook up the wiring. Here is a picture of the completed switch panel.
I know this is an old post but there are rocker switches that will fit the OEM blank openings (no drilling required). Not a big fan of the drilling and mounting the switches on top of the blanks. They pop out too much and can be accidentally kneed.
The switch pictured below won't pop out as much. There is a big selection of etches to chose from and I think even they can be ordered custom etched.
Can you please provide the link the for blanks (switch blanks, 85¢ each?)
m_x
Oct 21, 2014 12:03 PM
stock0891
Jan 28, 2011 04:27 PM
polokid69
Oct 26, 2009 03:15 PM
OhNineFIT
Sep 3, 2009 12:19 AM
Mugen_Dom
Aug 7, 2007 01:26 PM
