Door Handle Rust Recall.
Old Dec 30, 2020 | 03:54 PM
Chitown Fit's Avatar
Anyone have their door handles redone because of a possible rust issue? I was informed by my local Honda Dealer that it would take around 6 hours to complete the recall work. No cost of course. I haven't had this done. My door handles seem great.
Old Dec 30, 2020 | 09:31 PM
2Rismo2's Avatar
I had it done. It's the door handle under the sheet metal. You can't really see it unless you lower the windows and kind of peek between the channels. Mine were definitely rusty. After you get it back, inspect the doors to make sure they don't knick the paint and that they don't smear the black goop that holds the plastic sheet to the door.
Old Dec 30, 2020 | 10:50 PM
James Butler's Avatar
Had mine done in 2016. Broke Inside plastic piece. Took a month to get another. Inside door panels rattled and were not snapped into place properly. Check for leaks as they may not put plastic inside doors back in properly. Worst recall job I ever saw. Look before you go in inside door to see rusted part. Check to make sure they actually installed the new part which is painted black.
Good Luck
Old Jan 1, 2021 | 01:09 PM
Thanks For The Responses.
I'm going to pass on the rust door handle recall.
Old Jan 2, 2021 | 10:36 AM
exl500's Avatar
I had it done with no issues.
Old Jan 2, 2021 | 08:33 PM
2015FITEX's Avatar
one of mine came loose after the idiots did the recall,unless your cars white, you may be OK to pass on it...you COULD, POSSIBLY,in theory spay it with rust preventive,but they gonna rust a bit
Old Jan 10, 2021 | 12:23 PM
Uncle Gary's Avatar
I had mine done when the recall first came up. The shop managed to dent my rear passenger side door in two places prying off the panel. They also didn't get the door panel on correctly so I had to take it back a second time. Oh yes, they refused to acknowledge that they'd dented the door.
Old Jan 10, 2021 | 10:58 PM
Jazu's Avatar
that's just wrong with a capital R.
Old Jan 11, 2021 | 12:33 AM
2015FITEX's Avatar
Jazu your living in the past...lol....its a capital N for No One Cares! anymore...craftsmanship is DEAD X
littleriver
Feb 5, 2018 02:15 PM
MotoFrost
Oct 31, 2016 03:55 PM
SilverEX15
Apr 8, 2016 12:25 PM
SilverEX15
Feb 12, 2016 09:04 PM
lip008
Feb 10, 2016 10:56 AM
