Speedometer gone crazy
Old Jan 23, 2021 | 02:47 AM
ctbear's Avatar
Exclamation Speedometer gone crazy
Posted in the General section but I think it might be a better fit here.
2015 Fit EX
Speedometer has been randomly going crazy (usually reading an absurdly high speed).
Yesterday, I was cruising down a residential street at a constant speed with other cars alongside me when suddenly the speedometer kept climbing until it was reading 100+ mph. No way I'm that reckless.
Issue comes and goes randomly. Usually occurs when I'm on the highway, reading that I'm going 80mph+ when that isn't possible with all the traffic around.
Also noticed for the first time recently that the needle stayed stuck at 65mph even after I turned the engine/car off.
Picture attached
Car is off and parked in this picture
Is this an issue with the instrument cluster? Or the Vehicle Speed Sensor(s) ?
Old Jan 24, 2021 | 06:30 AM
saveMT's Avatar
Maybe plug in one of those OBD2 real-time tools and see if it also reads insane numbers when the speedometer is doing it.
If both are showing weird numbers, it's more likely to be the sensors. If not, it's more likely the meter itself.
I personally use Blue Driver, but there are many others that you can hook up to a phone to see real-time data.
My guess with little data I have is that it's the meter itself, because if wheel sensors are misbehaving, other things would go crazy, too, like TPMS, ABS, and what not.
Old Jan 24, 2021 | 09:48 AM
wasserball's Avatar
I would try to reset all the electronics by disconnecting the battery, wait, and reconnect.
Old Jan 24, 2021 | 11:34 AM
bargainguy's Avatar
My sense is that there's a bad connection between the speedo cable and the crankshaft. Otherwise, no way can it register 60+ mph with the engine off. I think you're looking at a speedo cable replacement.
Old Jan 25, 2021 | 09:31 PM
ctbear's Avatar
Are you referring to the electrical cable that is connected to the Vehicle Speed Sensor that is attached to the transmission? I guess I would have to trace that line somehow.
I'll try to catch it one of these days misbehaving with my OBD2 scanner to reference what it is actually sensing speedwise.
Old Jan 25, 2021 | 11:05 PM
wasserball's Avatar
Where does the sensor sense speed? Certainly, not the crankshaft since speed depends on the gearing, not just rpm from the crankshaft. And, modern cars don't use a mechanical cable.
Old Jan 25, 2021 | 11:15 PM
ctbear's Avatar
I tried to find drawings on the VSS for our cars but it seems like there may be multiple VSS(s) (?)
Old Jan 26, 2021 | 01:25 PM
Jared592's Avatar
Check the wiring going to the CVT speed sensor (assuming you have the CVT, otherwise there's an equivalent sensor for manual), see #16 in the diagram below:
Part# 28810-R9L-003
Old Feb 1, 2021 | 03:39 PM
Stephanie Duncan's Avatar
Instrument Cluster was replaced
I had a similar problem and it ended up with the delearship having to replace the instrument cluster which is a huge pain and will complicate trade in/resell because it involves "tampering" with the odometer during the replacement.
I hope yours is not that complicated.
Old Feb 2, 2021 | 09:06 PM
2015FITEX's Avatar
i would replace the vss listed above. if that yields no positive results ...it may be soldering time on the instrument cluster as a fuel gauge fix on the forum points out
wasserball...its in the transmission basically,like you say ,it needs to be........the 1997 predule when crazy last year.....zero....180...zero....automatic didn't like that but still functional...cheap fix VSS
Jasonvicktory86
Oct 4, 2019 11:49 AM
KKiernan
Aug 18, 2019 05:19 AM
User1
Jun 27, 2019 12:39 PM
vinylengraver
Sep 27, 2018 10:49 PM
Sid 6.7
Dec 30, 2008 04:27 AM
