Backup camera and gear shift indicator light
Old Jun 1, 2021 | 07:52 PM
bplegend's Avatar
Hello, I have a 2016 Honda Fit LX. There are two problems and I am not sure if they are related.
- The backup camera is not showing anything when I put into Reverse gear. The display doesn't change. It remains in the Main screen as if nothing has changed in gears.
- I found the gear shift indicator light also not displaying the R gear. All other gears display correctly in the indicator
I checked the backup fuse (29) and fuse looks fine. Anyone has any ideas what to look?
Old Jun 1, 2021 | 08:24 PM
bargainguy's Avatar
So reverse works fine, it just doesn't show R on the display, and the camera doesn't activate?
I suspect a bad sensor. That would explain why the backup camera isn't activating - the system doesn't think it needs to.
There might be a system override functioning here, whereas if you put the gear lever in the correct position for R, the transmission will automatically go into reverse even if the sensor is bad. Kind of a limp-home mode. Otherwise you wouldn't be able to get into reverse at all.
Old Jun 1, 2021 | 09:21 PM
bplegend's Avatar
yah backing up works fine. Just no display and R on the indicator.
Is the sensor in the transmission?
Old Jun 1, 2021 | 09:42 PM
bargainguy's Avatar
Don't know, but I just thought of another question. Do your backup lights engage in reverse? If not, could be a real safety hazard.
Old Jun 1, 2021 | 09:59 PM
bplegend's Avatar
Hmm.. True. Let me ask my wife to check for me. Good idea.
Old Jun 2, 2021 | 12:05 AM
BMWguy22's Avatar
Yeah, just conveniently place your wife behind your reversing car
Sounds like something I've seen on one of those crime shows where the husband offs the wife for the insurance money.
"don't worry honey, I just need you to tell me if the backup lights come on!"
Old Jun 2, 2021 | 10:58 AM
bplegend's Avatar
Yah. backup lights don't come on. Just ordered an OBD reader and will see what it comes up.
Old Jun 2, 2021 | 07:24 PM
jscene's Avatar
Yeah, 29 is a 10A fuse called "Back Up" but there should be another, a 15A in position 21 called "Back Up Main" you could check.
Old Jun 2, 2021 | 09:54 PM
bplegend's Avatar
Just checked fuse 21. It looks fine.
Old Jun 2, 2021 | 10:03 PM
howarejew's Avatar
Check the transmission range switch. It tells the PCM what position the gear selector is in.
Old Jun 2, 2021 | 10:32 PM
bplegend's Avatar
sounds right. But that is a heck lot of things to take off.
Kazu
Fit I.C.E.
Mar 14, 2019 02:16 PM
QuiGonQuinn
Aug 31, 2018 07:52 AM
DonasGD
Jun 12, 2017 12:36 PM
Agrajag
Oct 13, 2016 12:51 AM
Zute
Aug 30, 2014 10:07 PM
