Rear driver side wheel locked up
Old Jun 7, 2021 | 02:29 PM
IRev2NineK's Avatar
Whats up guys. Just trying to get some input and to see if anyone else had this issue. Washed my '17 Fit last night, and this morning, when I tried to back the car up, I noticed the rear driver side wheel was not moving. Ebrake was disengaged all the way and the rear passenger side wheel has no movement issues.
Didnt have much time to try to do too much trouble shooting since I was pressed for time, but I did try engaging and disengaging the ebrake with no luck. I also tried to rock it free by putting the car in drive then reverse for a couple minutes with only light application to the throttle.
Just wanted to get some input on if its happened to any of you and what yall did to get it to get it going again before I start pulling it apart. TIA
forgot to mention it was about 55 degrees last night, so not cold enough to freeze anything. When I googled the issue seemed like most folks who had my issue all had their car sit overnight in rrally cold weather.
Old Jun 7, 2021 | 03:57 PM
bargainguy's Avatar
If it's happening only on one side, that means that there is an obstruction only on that side, otherwise both your rear wheels would be locked. It implies the obstruction is after the splitter to each rear wheel.
I'd get underneath the car and see if you can trace the parking brake cable route on the obstructed side by hand. That might tell you where and what the obstruction is.
Socal typically doesn't see freezing temps, so hard to believe you froze anything, but I suppose it's a remote possibility.
Old Jun 8, 2021 | 09:55 AM
Fuelish's Avatar
Since you mentioned you washed it, could the brake have rusted? Happened to my son's old car when it was being scrapped....it "ran" but the one (or both) rear wheels wouldn't turn....they dragged it with the tow truck for a few feet and it broke free....just a thought
Old Jun 8, 2021 | 01:20 PM
2015FITEX's Avatar
bang brake drum with giant hammer..brakes rusted on
Old Jun 8, 2021 | 03:51 PM
IRev2NineK's Avatar
Once I got home from work I decided to jump in and try the rock back and forth method but this time, give it the beans. The brake finally broke loose. Drove it around for another ten minutes to make sure there were no other weird behaviors and to make sure the brakes are still in working condition.
Old Jun 8, 2021 | 03:53 PM
IRev2NineK's Avatar
Seemed like it was just rust like another member stated
Old Jun 8, 2021 | 03:55 PM
IRev2NineK's Avatar
Update: seemed to be rust the seized the brake. I hopped in the car and gave it the beans in reverse and drive and eventually it broke loose. Drove it around for a few miles to make sure there arent any weird behaviors or vibrations and she seems like she is fine. Thanks everyone who respondes. The Input was appreciated
Old Jun 8, 2021 | 05:16 PM
woof's Avatar
Out of curiosity are you near the ocean where salt spray could have gotten at the car? It's hard to imagine what else could have caused the rust given your location.
Old Jun 8, 2021 | 05:34 PM
IRev2NineK's Avatar
Not at all. Just plain tap water to wash the car.
Old Jun 8, 2021 | 11:13 PM
2015FITEX's Avatar
good call fuelish!
Joe Henry
Feb 4, 2021 11:54 AM
jjbankhead
Mar 23, 2020 04:49 PM
aelk799
Oct 2, 2017 03:01 PM
Glockbag
Jul 20, 2015 08:01 AM
jits14
14
Sep 5, 2006 09:32 PM
