Click, no crank, slow cranking....
Old Oct 7, 2023 | 03:29 AM
530Wheeler's Avatar
Just started having a cranking/starting gremlin, i tend to ramble but ill try to keep this short and sweet....
2016 Fit, CVT, Key ignition, original starter and alternator, battery is about a year old DieHard flavor 151R sized
Started about 2 days ago, hopped in to go to work and turn the key and clickclickclickclickclick so i hooked up my jump box and it fired right up and away i went, got to work and killed it then immediatly tried to restart and clickclickclickclick
Leaving work same thing, used the jump box and away i went, the next morning i put the battery on my charger but it read 100% charge so i put it back in the car, turned the key and just clicks but it eventually started to crank veeeeryyy slowwwing then sped up and fired the engine....
drove to work, killed it then immediately tried to start again and it fired right up...leaving work same thing as before, clicking then super slow crank which eventually sped up and fired, let it idle and dome light was flickering...
no idiot lights on, battery still reading 100% when i put it on the charger...checked fuses and all are ok....thoughts?
Old Oct 7, 2023 | 09:46 AM
saveMT's Avatar
First thing I'd do is to actually test the battery. Neither the age nor the charge level will tell you the whole story. It's the cranking amps it's willing to put out.
A lot of auto parts stores will test them for free.
Now, if the battery is bad, I assume you can get some sort of warranty on it, if prorated.
Beyond that, if it wasn't a lemon battery, you might need to dig deeper. Charging system working good? A loose ground somewhere? So on and on.
Old Oct 7, 2023 | 10:49 AM
woof's Avatar
Yup. Get a proper test of the battery done with a load tester. And check the battery connections to make sure they're not loose or corroded. Clean them off and re-tighten.
Old Oct 7, 2023 | 02:15 PM
530Wheeler's Avatar
Ill be taking the battery to get tested today, to test the alternator where exactly do i place the leads on my multimeter...? ive checked the ground right on the frame next to battery and it looks good clean and tight, where are others i should check?
Old Oct 7, 2023 | 04:51 PM
2015FITEX's Avatar
i have started having a vaugely similar issue at 53k and am about to change the starter. i also have a one month swapped 51 battery and heard the + post can be a bit smaller so im also going to file the gap on the bolt bigger in the + connector because its TIGHT, but it looks like its tight on itself,not the terminal. odd the dome light flickers
Old Oct 7, 2023 | 08:36 PM
530Wheeler's Avatar
Took the battery and had it tested at Riebes and sure enough the second he hooked it up it started screaming, 210 available CCA out of 370
Bought a new group 51R, dropped it in and shes been back to normal all day
**both battery posts on my new 51 Napa battery are the same size as factory
bleakly
Oct 5, 2023 06:02 PM
ernie88
Jun 6, 2023 03:12 PM
ritholtz
Dec 2, 2018 12:02 PM
Lenae
Sep 5, 2018 03:14 PM
tonkatsu
Oct 17, 2013 12:51 PM
