Replacement Apple CarPlay USB port?
Old Feb 20, 2025 | 11:41 AM
Cruciarius's Avatar
Unhappy Replacement Apple CarPlay USB port?
The Apple CarPlay USB port on my Fit seems to be going bad. Had an adapter plugged into it for a wireless option. The adapter is a very short cable permanently connected to a small transmitter box, so it dangles over those 2 center cupholders. Recently I've had connection issues to said wireless option, so I figured that was the issue. Ordered a new wireless CarPlay dongle before I tried other options, like an idiot. After placing the order, I tried a cable right from the iPhone to the USB port, but turns out it doesn't always work and when it does, if the cable is touched/adjusted, connection gets lost. I have tried a few cables, including official Apple ones. No luck. Have not looked into how the USB port connects to the stereo unit, but I am really hoping it can be unplugged for a new one and not hard wired into the stereo. I've been out of luck trying to find a replacement part so far, but the search continues.
Has this happened to anyone else? Suggestions?
Edit:
Forgot the year/trim. 2018 Honda Fit EX
Old Feb 20, 2025 | 03:22 PM
bobski's Avatar
What year and trim?
Old Feb 20, 2025 | 03:41 PM
Cruciarius's Avatar
2018 Honda Fit EX
Old Feb 20, 2025 | 06:02 PM
bobski's Avatar
I see what I think is the part you need in the diagrams (Interior / Bumper > Instrument Panel Garnish (Passenger Side)), but its reference number isn't in the parts listing. The USB socket in the arm rest (which you could probably use for your wireless adapter without issue) has the same problem. The closest listed part by the cup holder is 39115-T5R-A51 "Hoder Assy., Usb", but I suspect that's the bracket that the actual connector part snaps into, along with the flip-up lid - no electrical connector insert. I believe 39116-T5A-G01 "Sub-Wire, Usb (Instrument)" is the cable from the socket back to the infotainment unit... It *might* include the part you need. You could ask your nearest dealer to order both of those, then keep whichever one has the actual USB socket. If neither includes the socket, give them an earful for not selling an easily broken part.
Old Feb 21, 2025 | 12:50 AM
howarejew's Avatar
39116-T5A-G01 "Sub-Wire, Usb (Instrument)" is the USB going to the center console. Won't work because the sockets on the back of the audio unit are shaped slightly different for both plugs.
Part number for a 2018 Fit USB cord is 39113-T5R-A12 CORD ASSY., USB (CONNECTOR:GRAY/BLACK)
Old Feb 21, 2025 | 10:16 AM
bobski's Avatar
It's the cord going to the port on the Instrument Panel (dashboard), which is where Cruciarius said their broken port was.
I believe that cord goes from the audio unit to the USB port in the arm rest compartment.
Edit: I see the point of confusion now. The diagram for the "(Instrument)" version shows the cable out of place with what appears to be a length measurement over 2 meters. Seems that somebody paired the part description with the wrong diagram. Conflicting technical information is SOOOO helpful.
Old Feb 21, 2025 | 11:22 AM
howarejew's Avatar
The diagram is correct. 39116-T5A-G01 "Sub-Wire, Usb (Instrument)" is the USB going to the center console. 39113-T5R-A12 CORD ASSY., USB (CONNECTOR:GRAY/BLACK) is the cord going to the dashboard.
Old Feb 21, 2025 | 11:30 AM
Cruciarius's Avatar
Sounds like 39113-T5R-A12 is what I need then?
I wish this had a picture of it:
Honda Parts Connection
Happens to be on sale as well.
Old Feb 21, 2025 | 11:57 AM
bobski's Avatar
That's a solid MAYBE.
Old Feb 21, 2025 | 12:10 PM
howarejew's Avatar
Old Feb 21, 2025 | 02:49 PM
bobski's Avatar
#4 being the holder, #2 being the confusing part:
Old Feb 21, 2025 | 03:59 PM
howarejew's Avatar
#2 is not applicable for 17+ Fits, only '15 and '16
This is from my '18 Fit. The USB cable just goes straight into the holder.
Old Feb 21, 2025 | 06:25 PM
bobski's Avatar
Nice. I assume the connector on the other end of the cable is grey?
Old Feb 21, 2025 | 07:09 PM
howarejew's Avatar
I'm not about to pull out my radio to check
Old Feb 21, 2025 | 07:33 PM
bobski's Avatar
Was worth a shot. ^_^
Old Feb 21, 2025 | 09:16 PM
howarejew's Avatar
I'm still curious as to what #2 is. Anyone with a 15-16 Fit wanna check?
Old Feb 22, 2025 | 12:05 AM
bobski's Avatar
Knowing what year to look at makes it easy. 39112-TY2-A01 "Adapter Assy,Usb". MSRP is over $100, so maybe leave it alone? o_O
From the looks of it, it adapts whatever automotive-grade-positively-latching-but-not-technically-a-USB-connector Honda is using to a standard USB-A socket. That makes a lot of sense to me, as it gives the wiring harness cable an easily (cheaply) replaceable end, for exactly the scenario we're dealing with here. It should be two connectors (one of which can be purchased for pennies) in a housing (which likely includes the other connector's shell) that snaps into the holder/lid component. $10 would be exorbitant. Every time I look at Honda parts prices, it makes me think they're a "problem" company.
Actually:
That looks a LOT like it could fit the end of the cable you posted. What was inside your holder/flippy-lid part?
BrokeMyFriendsFit
Dec 27, 2021 06:54 PM
LLLC1393
Oct 18, 2019 05:00 AM
asherlc
Apr 8, 2015 05:43 AM
postman41258
Jun 24, 2014 02:51 PM
fitscott
Feb 19, 2010 01:30 PM
