Headlight Bulb Brand?
Old Nov 29, 2025 | 11:20 AM
Chitown Fit's Avatar
No Aiming Needed.
Originally Posted by bobski
No LED bulb-replacements are DOT road-legal for headlights. None. That means there's no legal framework, standards, or requirements that guide or limit the construction of such LED units. It's a engineering wild-west that escapes scrutiny by labeling the products as "For Off-road Use Only" or "For Fog Lights Only".
Checking your headlight aim is the least you can do after installing such a product. You don't even need to be precise about it. Find a nice flat parking lot at night, turn your headlights on, low beam. Lay a towel over/in front of the headlight you're not testing to block its light. Find the center of the headlight lens (the reflector portion that does the actual headlight-ing), stand right next to the headlight and find that center spot on your thigh, put your fingers there to mark your leg like a ruler. Walk ~15 feet out in front of the car and use your body as a screen to find that headlight's hot spot - where the headlight beam is brightest. The hot spot should have a well-defined upper edge. Follow the hot-spot-beam out to about 50 feet and compare its upper edge to your leg-ruler. The upper edge of the hot spot should always be at or below your headlight-lens-center measurement. Road surface flatness of your testing area is very important for proper results, so re-position the car and test again if you have any doubt. If the beam is too high (shining in other drivers' eyes) or too low (not shining as far down-road as it should), it can be adjusted with a cross-head (Phillips) screwdriver. Swap your towel over from the other headlight and repeat.
The H4 LED lights I installed have the same beam pattern as the Halogen lights I had.
No aiming of the beam pattern needed.
Old Nov 29, 2025 | 11:38 AM
bobski's Avatar
I guarantee you they are at least subtly different. No LEDs exist that combine the size, shape, and intensity of halogen filaments. The closest products put surface-mount LEDs (~170° light spread at best) on the front and back of a circuit board with a metal or ceramic core (for cooling). The circuit board and light spread create "blind spots" that halogen bulbs don't have, not to mention any other cooling or mounting features. The very LED "bulbs" you posted have a hard shoulder on their base that shadows part of the reflector from the high-beam LED.
That's a nice assertion you got there. Have you actually verified it?
Old Nov 29, 2025 | 03:50 PM
Verification Of LED Beam Pattern.
Yes.
When I drive at night I can see the beam pattern and light intensity.
Halogen lights are dull compared to LED lights.
The LED lights I have are non adjustable.
Just install like a Halogen light and drive.
The DRL's are alot brighter and more visible during the day than the Halogen lights.
I'm never going back to Halogen lights.
Old Dec 18, 2025 | 10:19 PM
MTLian's Avatar
Dirty Fit with stick halogens.
Dirty Fit with stock halogens.
Stock halogen beam pattern.
Left with LED, right with stock halogen.
Beam pattern with both LEDs installed.
Dirty Fit with LEDs installed.
Following Chitown’s post, I bought some Sealight Scoparc LEDs and installed them in a random alleyway at night.
required tools: flashlight, pliers to remove rubber boot for the first time, clean disposable gloves.
The scatter is very similar and the auto adjusting of my phone camera doesn’t do the new headlamps justice. I didn’t feel like I needed to adjust the headlights down and I agree with Chitown that the scatter pattern is quite similar to stock, only the light is at least 3 times brighter (subjectively). Once the snow clears, and I find a nice flat surface, I’ll do a proper headlight beam adjustment but pretty much drop in and go.
took me about thirty minutes because I took my time installing one bulb at a time and taking pictures plus checked my oil level while I was in there.
SilverEX15
Jan 3, 2025 05:45 AM
SilverEX15
Jan 2, 2025 01:52 AM
JodysTransmissions
Feb 22, 2017 03:48 PM
crushbent
Apr 20, 2008 06:08 PM
