Fuel Mileage Related Discussions
Old Apr 10, 2015 | 02:42 PM
  #541
Redd's Avatar
Yeah watching the instant MPG gauge helps me more than the colors.
Whenever I need to step on it I say "Time for BLUE SPEED"
Old Apr 10, 2015 | 02:58 PM
  #542
Bassguitarist1985's Avatar
Naw Naw Blue Speed is too slow. We gotta go right to....LUDICROUS SPEED!
Old Apr 10, 2015 | 05:56 PM
  #543
JustCallMeCole78's Avatar
Originally Posted by Uncle Gary
Yeah, I just go "ooh, look at the pretty colors"
Haha love it
Old Apr 10, 2015 | 07:26 PM
  #544
Redd's Avatar
Ludicrous speed?!? I don't think this car can take it.
Old Apr 13, 2015 | 07:19 AM
  #545
GoBucky's Avatar
Its nice to see consistent temps in the 40s and 50s. I love this little engine. Here's proof that it's finally getting warmer (this is a picture of my tank history screen taken after my morning commute today):
https://www.dropbox.com/s/9bttffowrw...50627.jpg?dl=0
Old Apr 13, 2015 | 07:31 AM
  #546
John Kuhn's Avatar
Originally Posted by GoBucky
Its nice to see consistent temps in the 40s and 50s. I love this little engine. Here's proof that its finally getting warmer:
Wow, those are some impressive numbers!
Old Apr 13, 2015 | 08:00 AM
  #547
GoBucky's Avatar
The Current Drive mpg is a bit of a misnomer, that is the result of just 2 trips (35 miles and 25 miles) and both were with a tailwind. That number will be dropping for sure, unless I can somehow work it out such that I only drive with the wind. But, at least temporarily it looks pretty cool.
Old Apr 13, 2015 | 08:13 AM
  #548
SilverEX15's Avatar
Yes Honda can do something, but that's on Honda, not the dealership. There's not much the dealer can really do other than tell Honda about the issue and hope they do something.
Maybe I would expect the dealer to do THAT, but then again I am sure it would be low on the priority list for their engineers.
Also how do you know that's what will fix the problem?
This is a non-issue. I can see a manufacturer eliminating that feature if people complain that the car doesn't agree with their calculator. Big deal!
That's one reason that temperature gauges went electronic and stopped giving accurate readings. People complained to the dealers that their cars were "running hot" when the needle move a little bit.
That's one thing I miss in the Fit. I like to keep an eye on the temp gauge, especially for turning on the heat in the winter.
Old Apr 14, 2015 | 02:36 PM
  #549
TequilaSqueela's Avatar
It is most likely my fault, but I can't touch any of the reported mileage here. I've only driven my first tank so far, but my 2015 EX Manual got 26mpg. I was shifting when the colors would turn blue and do highway driving with 2/3 lights every day.
This tank I decided to ignore the lights and drive it like my Miata. We shall see what happens... I'm pleasantly surprised by the nice little throaty growl this car makes when breaking 3k on the tach.
Old Apr 14, 2015 | 03:18 PM
  #550
SilverEX15's Avatar
I don't think my engine knows it can rev to 3K.
Old Apr 14, 2015 | 08:21 PM
  #551
jetto-setto's Avatar
The ups and downs of the highways down here in SoCal really hurt my mileage. There's a huge difference between when I take a drive down to San Diego (I think 38 mpg is my best, round trip), and when I go up to Orange County or something (generally flatter roads, and usually 40-42mpg).
I just did my first oil change at 3800 miles - only did it early because of a several thousand mile road trip I plan on taking soon. Filled it with a Japanese-spec motor oil approved for the L15B which should maximize fuel economy. I plan on doing a UOA after 5K miles to see how the oil held up, and I'll also see how it affected my mileage.
Old Apr 16, 2015 | 11:07 PM
  #552
John Kuhn's Avatar
Actual vs indicated mileage, and tank capacity
My wife filled our new Fit for the second time today, both times filling it to where she could see liquid fuel in the filler neck. For that tank the display said 41.0 mpg, the calculation came out 39.4 mpg, so about 1.6 mpg optimistic. Same number as some have reported, although others reported no error.
Anybody know if it is a bad thing to fill the tank all the way to the top? She said both times she filled it, she was able to put two more gallons of fuel in after the pump first kicked off!! Concern maybe regarding fuel expansion. She likes to stretch the time between fills (her previous car was a VW TDI that would go 600 miles on a tank).
10.3 gallons went in shortly after the light came on, but I should think there was a gallon or more actually left in the tank for reserve. Rated capacity 10.6 gallons must not reflect a complete fill.
Old Apr 17, 2015 | 07:05 AM
  #553
GoBucky's Avatar
I always get about 1.5 gallons more after the first click of the pump. The pumps are all different but I've never seen anywhere near 2 gallons yet, that pump must shut off a little earlier than the ones I use. The most gallons I pumped in so far was 11.2, so yes, the tank has some reserve. And I won't fill mine all the way to the very top, I fill it to where I can see it at the top of the filler neck, but then it recedes a bit.
Old Apr 17, 2015 | 07:33 AM
  #554
SilverEX15's Avatar
Definitely not a good idea. As you said, fuel expands, even when it's not above 90°. Unless you don't know where you'll be able to find gas for your next fill-up, what's the point?
Old Apr 17, 2015 | 07:58 AM
  #555
GoBucky's Avatar
Doesn't the GK have a vapor recovery system canister that could get damaged by overfilling? I know it's not very common that it gets damaged but if you overfill every time such that it gets saturated with fuel, it could damage it. But again, the fuel would have to overflow into the recovery system repeatedly for that to happen.
Old Apr 17, 2015 | 08:15 AM
  #556
John Kuhn's Avatar
That was my concern, I'll suggest to her to go no more than one gallon after the first click.
SilverEX15, the point is simply to go further between fills, but obviously not worth damaging anything.
Old Apr 17, 2015 | 10:02 AM
  #557
Redd's Avatar
last week I tried filling up to the first click and the MPG was within .1 of the meter on the dash, but I could still add another 1/2 gallon after that to the 2nd click so obviously it was off by 2 mpg or so afterwards.
Also when I put the nozzle in, it's not inserted as far as it will go, it's maybe 1/2 way.
Edit: I filled to one click again today and it was within .5mpg of the dash
Old Apr 17, 2015 | 05:04 PM
  #558
SilverEX15's Avatar
I had an old English car, a '52 MG, and there was one section of the owners manual that took me a long time to translate. "Do not fill the fuel tank until fuel appears in the filler neck."
Old Apr 17, 2015 | 08:13 PM
  #559
Yeah, the owner's manual was correct. Plus, on modern cars (as mentioned above) there are other systems that can be more easily damaged than in the past by over-filling. Just stop filling when the pump clicks off.
Old Apr 19, 2015 | 01:19 PM
  #560
kram80122's Avatar
First, what is GK? I've had my Fit EX for almost nine (9) months, and use the ECO option. I tend do mostly city driving, with an occasional highway trip. The computed MPG had been pretty spot on when I calculate actual MPG at full up. That said, I'm averaging only about 28 MPG, lower than what was advertised. And MPG for total mileage is under 30. Again, less than touted.
