LX trim have high beams?
Old Apr 8, 2015 | 11:13 PM
dcoaster's Avatar
Stupid question I know, but does this trim have high beams? I attempted to turn them on (pull back/push forward on the headlight stick) while I was driving, but the headlights just turn off. Am I missing something here?
Old Apr 8, 2015 | 11:35 PM
GreyFit15's Avatar
just push
Just push the whole stick forward . You might have to push more firmly than your used to. I had to get used to the difference between my lx and my old car , a Chrysler.
Old Apr 8, 2015 | 11:38 PM
dcoaster's Avatar
Yep, I've been able to do that. I even get the indicator for high beams to come on the dash, but the headlights simply turn off and no high beams. If I push back and it locks into high beam mode, the headlights are steadily off (with the icon on the dash but no high beams). I just got it this weekend... guess I should take it into the dealer to see what's up?
Old Apr 9, 2015 | 12:36 AM
andre181's Avatar
Definitely take it to the dealer. Something is wrong.
Probably a bad switch or relay.
Old Apr 9, 2015 | 07:50 AM
DWils's Avatar
Or a blown fuse for some weird reason.
Old Apr 9, 2015 | 05:32 PM
dcoaster's Avatar
Took it to the dealer and turns out it was a blown fuse... very peculiar for a 4 day old car. I really hope this doesn't turn into a cascade of problems for a 'reliable' Honda...
Old Apr 9, 2015 | 07:24 PM
DWils's Avatar
Glad to hear it was just a fuse instead of a larger problem. Although you might have only bought it four days ago, it was probably built a few months ago and fuses are one of the many parts that wear out and will eventually need replacing.
Old Apr 9, 2015 | 09:09 PM
Bassguitarist1985's Avatar
If it makes you feel better, my dome light, low beams and accessory adapters did not work. Dealers often pull these fuses so as not to drain the battery when its sitting on the lot. In my case they simply forgot to put them back in. Drove back, told them, they apologized, and installed the fuses on the spot. All was good.
dsl
19
Oct 14, 2014 04:14 PM
linnboi
25
Oct 4, 2012 10:21 AM
rsawn
Mar 18, 2012 09:23 AM
Gordio
Aug 8, 2010 09:09 PM
IVTEC
Dec 25, 2009 10:37 PM
