Valve adjustment Feeler won't fit
Old Apr 29, 2015 | 10:17 PM
bigalttd1's Avatar
I go to the #4 cylinder set of valves and on the exhaust side the feeler gauge won't fit under even after I backed off the adjustment screw. Both exhaust valves are stuck (not really the valve)
Does this mean it's stuck? Should I gently use a pry bar to lift it up ever so gently? Any ideas?
Any help is appreciated.
Old Apr 29, 2015 | 11:25 PM
DrewE's Avatar
I sometimes have to remind myself to check the obvious things again. Is the crankshaft in the correct position for adjusting those valves (and on the correct alternate rotation)?
amberd03
Aug 20, 2017 11:57 AM
sunnyday
May 27, 2017 09:18 AM
doctor J
Dec 20, 2015 12:55 AM
icedmocha
Feb 9, 2015 05:58 PM
gizmodog
Nov 17, 2013 09:20 PM
