My misfire experience
Old Sep 3, 2015 | 02:17 PM
CommanderSlug's Avatar
16,500 miles on 2015 DX 6MT:
Check engine, traction control & steering lights come on at the same time over the weekend and stayed on. Car ran just fine; the check engine light never blinked/flashed on me (in which case it would be a clear misfire problem). I drop off the car Monday and dealer gives me a rental. 1 day later:
One of the cylinders was misfiring.
They replaced all coil plugs and all 4 injectors, along with a part of the fuel rail, as per service bulletin. All replaced under warranty. I am surprised they did not charge me for the rental.
Put on another 400 miles, no issues so far.
Update @23,000 miles: all is good.
Update @29,000 miles: all is good.
Last edited by CommanderSlug; Feb 7, 2016 at 09:06 PM. Reason: feedback update after more mileage
Old Sep 3, 2015 | 03:19 PM
2015FITEX's Avatar
well thats good it was fixed so quick.. i dont quite understand. did the check engine light, traction and steering lights STAY on ?...i dont quite understand what you meant by "the check engine light never blinked on me"
Old Sep 3, 2015 | 05:04 PM
exl500's Avatar
Just ran across the articles about the coil plug recall for 18k Fits a few minutes ago. Also a new thread on it here.
Old Sep 3, 2015 | 11:31 PM
All three lights stayed on continuously. Any blinking/flashing would indicate a clear misfire issue. Manual suggests pulling over and getting car towed to a dealer in case of blinking/flashing.
When I owned my Suzuki Esteem 1.6L 5MT, the check engine light would flash once in a while, and stay on otherwise. I never bothered to diagnose the problem since the car ran just fine, so I drove another 50,000 miles under those conditions. Little did I know, when the check engine light blinks, it's basically screaming at you: MISFIRING. If the check engine light stays on permanently, it may not be a misfire issue. In my case, it was a crankshaft position sensor electrical issue AND a misfire issue for the Suzuki. Then one day my fuel economy went down to 19 mpg. Car went to the junkyard at 170k miles.
mk2007
Aug 8, 2024 01:57 PM
BenQuick
Jul 22, 2017 06:04 PM
fr8train
Feb 1, 2016 07:26 PM
Stingray
Jan 7, 2016 05:14 PM
hondafitty
Jul 9, 2015 08:26 PM
