Waterproof solution for smart key?
Old Jun 8, 2016 | 02:50 PM
KayakPaddler's Avatar
Originally Posted by LVFit
And what do you do with the fob? Or do you not take the fob at all>? If you have an EX with push button start, don't you need the fob to start the engine?
There is no fob. I drive a 2016 LX 6 speed. The key is all metal; no plastic. It unlocks the door and nothing else. My key to start the car is locked inside the car when I'm ready to launch my kayak.
No waterproofing needed. Just have a lanyard on it and keep it in my PFD pocket.
Old Jun 8, 2016 | 02:56 PM
LVFit's Avatar
Ahh..ok. So if you have a smart key (push button start), this idea wont work since you can not start the car...
Old Jun 8, 2016 | 03:07 PM
No idea. I like to keep things simple: get in the car, turn the key, depress the clutch to get into gear, and zoom-zoom.
My radio also has knobs. Another reason I went for the LX.
Old Jun 8, 2016 | 03:10 PM
LVFit's Avatar
Guess I'll try it today.. Push button starts are nice but they have their own issues to work out such as this. I also do lot of activities that gets me in the water and don't want to risk the fob not working due to getting wet.
Old Jun 8, 2016 | 03:13 PM
Aquapac makes an excellent waterproof key case. Comes with its own lanyard.
Old Jun 8, 2016 | 05:49 PM
Uncle Gary's Avatar
I thought I read that you had an EX. Sorry.
If you have an EX with push button start the solution is simple. Separate the emergency key from the fob, hide the fob in the car, then use the key to lock the door. With the fob in the car the only way the door can be opened is with the key.
I just tried it and it works.
Old Jun 8, 2016 | 05:58 PM
Regdog77's Avatar
Get a lock box for a door at Home Depot and attach it to a tow hook on the car.
Old Jun 10, 2016 | 01:38 PM
tbFit's Avatar
Originally Posted by Uncle Gary
... With the fob in the car the only way the door can be opened is with the key. ...
Downside being, if someone breaks in, they can drive off with no effort with that keyless start FOB in the car. But that is a small risk that someone figures that out.
Old Jun 10, 2016 | 01:43 PM
LVFit's Avatar
My thinking exactly. If he pushes that button, car will start. Will the car start if the key is in the trunk? I'll have to test this.
Old Jun 10, 2016 | 07:16 PM
jtvisions's Avatar
Yes. I have tested this. The Fit is so small there is no place you can put the fob that the car will NOT start with the button. The only way I found to hide the fob was to remove the fob battery. The fob can still be used but has to be very close to button!
Old Jun 10, 2016 | 07:48 PM
LVFit's Avatar
Is there a way to block the signal from the fob?
Old Jun 10, 2016 | 11:16 PM
  #32
jtvisions's Avatar
You would have to put the fob in something that can block the RFID chip in the fob. That way the car can not 'see' it.
Old Jun 10, 2016 | 11:20 PM
  #33
LVFit's Avatar
Thats what Im saying. How do you block the signal?
Old Jun 10, 2016 | 11:32 PM
  #34
jtvisions's Avatar
I do not know what is available that would fit a fob. I am aware of sleeves for CC's and driver's licenses that block RFID. Someone mentioned using a small Altoids box. I tried that and it did not work. Maybe something lead lined? You would have to research this as I do not have an answer.
If you do find something please post it. I'm sure other Paddlers etc would like know.
Old Jun 11, 2016 | 12:23 PM
  #35
Jack Hammer's Avatar
Wrap the fob in aluminum foil. Simple, inexpensive, easy to source, and it works.
Old Jun 11, 2016 | 12:52 PM
  #36
jtvisions's Avatar
kEwL. Thank you.
Old Mar 21, 2017 | 10:33 PM
  #37
first honda's Avatar
I thought if they broke in the anti theft activates and car will not start unless they find the fob and deactivate (push unlock) it. Hard to test this out.
callie
Mar 26, 2017 02:09 AM
Fitodrive
Jan 18, 2017 07:06 AM
veazer
Jan 23, 2016 08:33 AM
tietack
Dec 2, 2008 11:42 PM
Bishop
Jul 2, 2008 02:40 PM
