Help!! Gk5 4 light sensors went on!!
Old May 20, 2016 | 11:46 PM
Exgk5's Avatar
Exclamation Help!! Gk5 4 light sensors went on!!
Hi guys!!
I need your help.
I have 2015 Honda Fit EX.
Im driving on the freeway like the normal cruise, when all of a sudden the car started to jolt, and right after that 4 lights went on the dash.
TPMS - blinking
Check Engine light
EPS (Electric Power Steering)
VSA (Vehicle Stability Assist)
I pulled to the shoulder, turned off the car for 10 or so minutes. Then i started it again, after that i tried driving it again, but its start to jolt again and i can't continue in the fear of breaking some more.
Now when i start the car, the smell is different and you know theres something wrong.
What do you think is the problem?
Checked all fuse, all good.
Battery is checked, all good.
All tires are checked, all good.
Fuel cap checked, all good.
Restarted the car, still shows the light on.
Please help!! Not sure what is happening.
Thanks in advance!!
Old May 21, 2016 | 12:53 AM
bach's Avatar
There a few threads in this forum about dash icons lighting up like yours, but I don't remember anything about the jolting. Can you somehow get the CEL code?
Old May 21, 2016 | 01:55 AM
ezone's Avatar
One check engine light problem causes a bunch of other systems to set related fault codes and be disabled. Figure out the CEL first.
Warranty? Drag it to your dealership.
Did you get the ignition coil recall done (if it applies to your car)?
Any other recalls?
Check here: www.recalls.honda.com
Old May 21, 2016 | 07:09 PM
Exgk5's Avatar
Can you tell me how to get the CEL code?
I'm a first time owner and not sure about a lot of things, since lack of experience.
Thanks for responding
Old May 21, 2016 | 07:10 PM
Exgk5's Avatar
Any other recalls?
I did all the recall, but i don't know if theres any about the ignition.
Thanks for the link!
Old May 21, 2016 | 07:13 PM
ezone's Avatar
Car is under warranty, go directly to your Honda dealer service department
Old May 21, 2016 | 09:34 PM
BrucesFit's Avatar
To get cel code you need a code scanner.
Old May 22, 2016 | 02:00 PM
Exgk5's Avatar
Code is 20
Old May 23, 2016 | 11:43 AM
BrucesFit's Avatar
Google came up with electrical load detector. (Eld) probably that fuse gone bad.
Old May 23, 2016 | 04:39 PM
ezone's Avatar
Code is 20
Which system would that code have come from?
If it is supposed to be an engine or transmission code, please use the standard OBD2 format of 'Pxxxx'
Old Jul 11, 2018 | 10:46 PM
RKM.'s Avatar
Sorry to bump an old thread, but this just happened with my Fit. Did you ever find out what the issue was?
Old Jul 12, 2018 | 02:29 AM
Exgk5's Avatar
No worries!
luckily i’m still under warranty then so i took it to the dealer shop and they said the water pump broke. Replaced that and all is good after that.
Sorry about your car. I hope it get fixed soon.
Old Jul 13, 2018 | 10:37 AM
RKM.'s Avatar
Appreciate your reply! A little update on my Fit: Took it to the dealer yesterday and had the fuel injectors replaced and all coils. Fuel injectors were under warranty, but the coils were not. The car is running well at the moment.
Santiad
May 6, 2021 12:05 PM
t_rave6
Jan 2, 2021 06:14 AM
live4ward
Jan 9, 2018 05:25 PM
patm95
Aug 25, 2011 01:50 PM
