Creaking Unless Parking Brake Is Extremely Tight : 2016 FIT
Old Aug 30, 2016 | 12:52 AM
ken.fit's Avatar
I noticed that when I get in or out of my Honda 2016 Fit, the rear will creak unless I tighten the parking / emergency brake really tight. It gets worse if I park on an incline. Any clues as to what's causing this? Is it just the e-brake or perhaps suspension.
Old Aug 30, 2016 | 01:33 AM
Fuelish's Avatar
Guessing e-brake, not unsual, at least from past cars I've owned
Old Aug 30, 2016 | 08:34 AM
Carbuff2's Avatar
Does the '16 have rear discs with the parking brake in the hub, or rear drum brakes?
If so, lubricating the shoe-to-backing-plate contact area would fix this if it bothers you.
Old Aug 30, 2016 | 08:38 AM
FitRaptor's Avatar
Have you tried without the e-brakes applied? That will point out where's coming from. Might be a bad strut. Goodl luck
Old Aug 30, 2016 | 10:34 AM
MrDucky's Avatar
Mine does this too. I always use the parking break every time I park.
Old Aug 30, 2016 | 01:42 PM
ken.fit's Avatar
I don't think it makes the creaking noise if the parking brake isn't engaged so it sounds like the e-brake is the culprit.
Is it bad to always engage the parking brake tight to maximum clicks? If it's just a drum brake shoe squeak then it's not too bad; just concerned if I should get something fixed while it is still under warranty.
Old Aug 30, 2016 | 03:42 PM
jhn's Avatar
jhn
When the suspension compresses, you get small adjustments in wheelbase. It's just the nature of suspension geometry. When you lock the parking brake, it prevents (resists) rear wheel rotation, which is needed when the suspension compresses from passenger weight loading/unloading.
What you're hearing is the rear brake pads squeaking from slight movement in the drums because of the wheelbase change. Pull it tight enough and there's no movement, therefore no squeak.
The noise isn't hurting anything.
Old Aug 31, 2016 | 06:06 AM
FitRaptor's Avatar
Yea dude that's just the pads trying to readjust while you sit on your car. Try loosing some weight or just let the pads get a little worn out
Old Sep 4, 2016 | 12:26 PM
HarleyBadger's Avatar
Mine does the same thing, and so did my 2013. I tried this in both cars, in neutral on a steep hill, and it will hold with just moderate pressure. However, I always stop, pull the brake as firmly as I can, and then shift to P (or R with the 2013 manual.) Still creaks when I get out.
Old Sep 5, 2016 | 09:26 PM
2015FITEX's Avatar
i would agree its not a huge problem, my other car 99 protege does this. its a bit early for this "old age"? problem though.
Old Sep 5, 2016 | 10:34 PM
TofuShop's Avatar
The creaking sound is the rear drums engaging when on a hill. It prevents the car from rolling backwards when on an incline. It's called hillstart assist. Completely normal
Old Sep 6, 2016 | 04:03 PM
Fuelish's Avatar
Ummm.... hillstart assist has nothing to do with the breaks creaking (normal) when getting out of a stopped parked car on an incline....just saying...think about it
wmo168
Mar 29, 2018 09:50 AM
cooper58
Feb 6, 2018 07:22 PM
ex-GD3
Aug 26, 2015 10:03 AM
dbcmaster
Apr 17, 2008 06:39 AM
doctordoom
Oct 17, 2007 03:34 PM
