oil change question
Old Nov 11, 2016 | 01:05 PM
bigbacon's Avatar
oil change question
how much oil do you guys normally get out of the engine when you do a change?
book says fill with 3.5qts but I got at least 4qt out of the engine + whatever I spilled all over the floor.
also...why are modern car oil dipsticks so freaking hard to read!!?!?
Old Nov 11, 2016 | 01:36 PM
Uncle Gary's Avatar
I never measured how much oil comes out, but exactly 3.5 quarts brings the level to the "full" mark.
I can't answer the "why" of you second question, but I agree with you. The dipstick is nearly impossible to read.
Old Nov 11, 2016 | 03:59 PM
cookiemech's Avatar
I find that the only way to get a good reading on the dipstick is to let the car sit a while (at least ten minutes), then pull the stick and read it. Putting it back in and reading it doesn't always give a good reading. Don't know why . . .
Old Nov 11, 2016 | 04:05 PM
2Rismo2's Avatar
I think it's hard to read because of the lightweight oil. This is the first car I've owned with 0w-20
Old Nov 11, 2016 | 05:14 PM
why use such a small drain pan?
get one of dese for next time. this is wat i use. makes for a quick drain into an empty washer fluid bottle for recycling.
https://www.amazon.com/Lisle-17942-B...=oil+drain+pan
Old Nov 11, 2016 | 05:23 PM
Westie's Avatar
I got a lil under 4 qts. Approx 3.9 with oil trapped in the oil filter when I did my 1st change. Filled with about 3.7-3.8 to the top of the mark with the filter pre filled prior to installing.
I think modern oil is hard to read due to the weight, and the stoopid orange colored dip stick that Honda has on the end of it.
When checking oil, I find it easier to remove the fill cap, pull the dip stick out, clean it and let the oil kinda drain back down from the dip stick tube, then grab your reading there. If not, it tends to smear the stick and mess up the reading. Also check the back side of the dip stick for comparison.
Old Nov 11, 2016 | 05:30 PM
i buy those 5qt jugs 0w20's at walmart. i fill the oil eye balling the gauge outside the jug to empty to 1qt left. doesnt matter if u are a tad over or under. just drive it for a couple of hundred miles and the oil will be a lot easier to read on the dip stick. i dont do anything special. just pull, wipe, dip, count to 5, pull to check. add as needed.
Old Nov 21, 2016 | 04:00 PM
GeorgeL's Avatar
I noted that my Fit was a bit overfilled when I received it and it didn't use any oil before the first change. I put in 3.5 quarts and that brought it to the full mark.
I have no problem reading the dipstick. I'd rather have a metal stick for better visibility (oil sticks to metal, not to plastic) but the stick provided is adequate.
Old Nov 26, 2016 | 05:51 AM
robs's Avatar
Wife's Toyota takes 6.5 quarts. Two jugs of 0w20 Mobile 1 and I'm in business!
Old Nov 26, 2016 | 08:47 AM
BenQuick's Avatar
Same here. I've had 2 oil changes since then and both readings showed a slight overfill, at least that's the way it looked.
Like others, I have a hard time seeing the fill line with this lightweight oil.
Old Nov 28, 2016 | 09:01 AM
salamlaith's Avatar
I did the first oil change, there was 3.9 QT oil
richsfit
Nov 7, 2012 06:10 PM
schwimmair
Aug 18, 2012 06:24 AM
Selden
May 10, 2010 02:08 AM
vwli
Jul 8, 2009 07:07 PM
phil_qc
Sep 6, 2006 01:23 PM
