Rust Under Lower Hatch Hinge In Welds
Old Mar 26, 2017 | 02:29 PM
Bob Levine's Avatar
Was waxing my 2016 LX and noted serious rust in the weld between the bottom of the hinge and the top panel of the hatch. Both hinges were affected.
Will take to Honda dealer soon to see if it is possible for the weld to get totally detached and let the top of the hatch drop off.
Coated the rusted area with white lithium grease to control rust temporarily.
Has anyone else had this issue? If so, what did Honda do? The car is under both 3/36 and Hondacare warranty programs.
Thanks
Old Mar 26, 2017 | 06:44 PM
BenQuick's Avatar
If memory serves there was a thread on this some time ago. But it may not have been the exact area you're talking about - can't recall for sure. I just went out and checked mine and they are rust free. The dealer should make it right for you and give you an explanation as to the cause - hopefully.
Old Mar 26, 2017 | 07:14 PM
Bob Levine's Avatar
Thanks.
Will probably be at Honda next week for an oil change (free), tire rotation, and to fix the rust issue.
Hopefully not serious but welds seemed to be well rusted and not smooth at all.
This is a good dealer.
Old Mar 26, 2017 | 07:16 PM
puffysweater's Avatar
Could you take a picture?
Old Mar 26, 2017 | 07:18 PM
Bob Levine's Avatar
Won't show since I coated the areas with white lithium grease to temporarily stop the rusting.
Old Mar 26, 2017 | 07:21 PM
Im kinda confused on the areas you're talking about. Id like to go check my car as well
Old Mar 27, 2017 | 04:07 AM
Bob Levine's Avatar
Open the back hatch.
Look at the hinges at the top.
The area under the bottom of each hinge is welded to the top of the hatch.
The weld area on my FIT is rusted (both sides).
Old Mar 27, 2017 | 05:55 AM
Take a pict show how bad.
My wife's GK is showing very minor rust on da hood prop hole.. never had dis on previous GD or GE's..
Old Mar 27, 2017 | 02:49 PM
Just checked! And yes, the bottom of the right hinge is showing minimal amounts of rust. Would this be covered under the "Rust Perforation Limited Warranty"?
"Rust Perforation Limited Warranty: Honda will repair or replace any body panel on your vehicle that rusts from the inside out. This
coverage extends for 5 years with no mileage limit."
Old Mar 27, 2017 | 03:23 PM
woof's Avatar
The key word here is "perforation". Surface rust would not be covered. The rust has to eat right through the metal creating a hole ("perforation"). The car companies know that the chance of that happening before any warranty expires is pretty much nil.
Old Mar 27, 2017 | 07:49 PM
Bob Levine's Avatar
Well, I found the answer and it was surprising.
As I mentioned, I put white lithium grease on the areas that appeared rusty to slow the spread of rust.
Checking again before making a Honda service appointment, I noted that the "rust" had loosened up. Cleaned it with clean and wax product. It was loose and wiped off.
The "rust" was actually some dirty junk from the road that sneaked into the gaps around the joint between the bottom of the hinge and the top of the hatch. The two parts do not fit exactly and crud can get into the opening.
Thanks to the grease, the crud was loosened so it could be removed.
I appreciate your help in exploring this mystery.
Old Mar 28, 2017 | 07:30 AM
sounds good.
i do find a lot of rust spots on da side of da car after winter. looks like rail dust and dey usually come off with some polish (ScratchX). u can clay it but just a pita putting da time on a car like da Fit cause its just a dd, polish and random orbital works so much faster.
Old Apr 3, 2017 | 01:00 PM
fitchet's Avatar
So the rust was really crust, -I trust.
Old Apr 3, 2017 | 01:24 PM
Bob Levine's Avatar
Yes, just dirt.
fittsburgh
May 23, 2020 06:22 PM
shawnshank
Nov 29, 2017 04:36 AM
raynist
Nov 2, 2015 09:51 AM
Dr. Unsped
May 10, 2011 01:20 AM
ThEvil0nE
Nov 5, 2010 12:56 AM
