Headlights which are affordable
Old Oct 4, 2017 | 10:20 PM
dwtaylorpdx's Avatar
you use the center socket to turn them, the service manual actually has the spec for how high the beam should be at a certain distance from a wall/garage door.
Old Oct 5, 2017 | 10:46 AM
Popeye's Avatar
I use PIAA high beam replacements on all my vehicles with zero issues and are perfect for rural driving ......... http://www.piaa.com/Shared/applicati...-Hi-Lo-Fog.pdf
Old Oct 17, 2017 | 09:04 PM
nomenclator's Avatar
Supposedly these will "work with DRLs." They do say they work down to 6v; most only work down to 9 volts. However my understanding is that the Fit supplies 5 volts to the (highbeam) filament for the DRL function - which of course is less than 6 volts. Also, the lumen rating is not clear. The spec stated is 4000 lumens per bulb - but does that mean 2000 lumens for each "filament" or 4000 for each filament? 4000 is kinda high, given that I think the orig halogens are about 1200 high beam, 900 low beam. Also, they say 6000 Kelvin color temp. That is slightly bluish and may attract unwanted attention. Cop "are your headlights legal?" 5000 is plain white, and closer to the orig halogens which are about 2500 to 3500 i think, depending on brand.
Old Nov 5, 2017 | 07:43 PM
I have been reading about various LEDs, which I describe in this thread.
Old Nov 5, 2017 | 07:53 PM
All that page refers to is PIAA brand bulbs, and what type you need to fit different cars. It doesn't say anything about any particular PIAA bulb types other than car fitment.
Old Nov 7, 2017 | 04:21 PM
The main problem i am having with the original headlights is not that the low beams don't let me see far enough down the road, rather, it is that the amount of light they throw to the right side, isn't enough to allow me to see where the road ends at the right, and where the ditch begins, or the cliff, and whether there is a large male deer quietly standing there and contemplating whether to dart across. Especially in regard to turning onto a side road.
Toephoo
Dec 10, 2014 12:54 PM
tommyohwhy
Aug 17, 2012 11:31 PM
Blackbeard
Jan 3, 2012 09:50 AM
R. P.
Aug 24, 2009 05:52 AM
halfmoonclip
Sep 3, 2008 08:52 PM
