Starter grind
Old May 21, 2018 | 06:41 PM
preludes&fit's Avatar
Starter grind
All, (2018 Honda Fit 6MT)
I stalled on a hill today and when I tried to start it up all I got was a grinding noise. Not sure why that would happen, maybe the teeth weren't lined up or something like that... is this common, are the starters problematic?
Old May 21, 2018 | 08:58 PM
Ok, just found the starter... the placement is insane, never seen a starter in the front. Probably not an ideal location, but should be easy to change if it is a persistent issue.
Old May 22, 2018 | 12:19 PM
bargainguy's Avatar
GK5 starter failure before and after the warranty expires is being reported here. Seems more prevalent on the pushbutton start models than the key start models.
If it repeats - or even just to be safe if it doesn't - might want to take it to a dealer and have it documented as an issue. This might help in case the starter gives out after the warranty expires and Honda balks on helping with the costs.
Old May 22, 2018 | 12:32 PM
Absolutely, documentation is key. Great point.
Sebas Td
Mar 2, 2019 11:53 AM
joe cool
Jul 23, 2018 10:44 AM
SevereService
Jun 25, 2014 08:02 PM
DCTepper
Nov 22, 2013 07:41 AM
ftlmatt
Jul 18, 2010 11:58 AM
